Global Profiles
Hey boys and girls. Have not attempted this yet, so thought I'd ask those of you who may have…
Granted the transmit profiles between the 6400 and the Aurora are going to be different, but anyone know if it's possible to import the global profiles from the 6400 series seamlessly to the Aurora?
yes
I would give consideration to just creating them from scratch. Others and I have had issues with profiles imported that caused glitches. In my case, there was no direct event when the glitch occurred that pointed directly to a profile import. I spent many hours over many months trying to troubleshoot, reproduce, and isolate the issue cause without success. In the end, I corrected the issue by starting with a clean slate and constructing everything, including the profiles, from scratch, and that fixed the issue when nothing else did. Certainly, I am not suggesting you should not import the old profiles but rather giving another thing to consider should issues appear after you have done so.
My attempt at importing did not work. It was easy enough to just make new ones on the Aurora.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 62 Aurora
- 975 Maestro
- 950 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 819 Peripherals & Station Integration
- 145 Amateur Radio Interests
