DAX audio bandwidth 96 kHz with 192 kHz sampling ????
Hello...
in my need to stream audio to Linrad software I need to get DAX audio bandwidth 96 kHz with 192 kHz sampling ...but I cant find any way to setup the bandwidth or sampling for DAX
any help ????
73" OZ1CT Ben
Hi Bent,
I assume you are looking for IQ data, right? At the bottom of the DAX panel, you can set the sample rate (max of 96000). I don't know how to set the width, but you could experiment with the panadapter width and see if that influences the IQ data.
Len, KD0RC
HI Len
No I was looking for the bandwidth of the DAX audio and also the sampling rate ??? not the IQ streams.
73" OZ1CT Ben
Trying to use my setup (Flex 6600 + transverters) with satellite's telemetries.
How could I expand the width of the audio DAX? It's always about 5.500 on the hs-soundmodem waterfall
Thanks and 730 -
The DAX audio stream is the same as the receiver slice audio stream. You can set your audio bandwidth in SmartSDR.
Any news about this topic @Mike-VA3MW ?
73 de EA5WA Juan carlos
If you have not already, you may wish to open a support ticket so they can pass it on to engineering.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 947 Genius Products
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
