AetherSDR — Open-Source Linux Client for Flex Radios
UPDATE: the Linux Version of AetherSDR 0.8.9 and 0.8.9.1 Audio are broken here for WSJTX so stay with 0.8.8 for now.
0.8.9.1 was supposed to fix the Audio issues but I don't think the fix got saved as 0.8.9.1 and is actually the broken 0.8.9
Hey Jeremy, great work on AetherSDR — this has been a long time coming for the Linux community.
Noticed you added a CW decoder for giggles in v0.4.13. I've been working on something that might be
worth a look before you go too far down that road. It's called OpenSkimmer — an open source Linux CW
skimmer I've been building with Claude as a co-developer (looks like we had the same idea there).
Quick tour:
- Full 192kHz band coverage via a polyphase filter bank channelizer — monitors every CW signal in the
band simultaneously, not just the active slice
- Three-decoder ensemble: uhsdr_cw (Goertzel, same core SkimSrv uses), libbmorse.so (Bayesian trellis,
AG1LE's decoder), all in C++
- Scores 56/67 on a dense CWT contest pileup benchmark — lightyears ahead of anything else available on
Linux open source
- GPLv3, so the licensing lines up perfectly with AetherSDR
The IQ stream from the Flex via VITA-49 is exactly what the channelizer eats, so integration into
AetherSDR would be fairly natural. What ggmorse gives you is a solid single-slice decoder — what this
adds is full-band skimming, which is a different beast entirely for contest and DX work.
Still actively developing but it's in good shape. Happy to connect and share more if you're interested.
73, Fred WF8Z0 -
I’d like to take a moment to sincerely thank everyone involved in the development of AetherSDR. Your work and dedication truly show in the quality of this project.
I’m currently running the client on a MacBook Pro M4, and it’s been working flawlessly. The performance, stability, and overall user experience are outstanding.
Projects like this make a real difference for the SDR community, and it’s clear a lot of passion and expertise went into making it what it is today. Thank you all for your efforts and for continuing to push things forward.
73, Roberval PS7TI1
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 59 Aurora
- 974 Maestro
- 947 Genius Products
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
