RimuSDR for Linux — Now Available
NV0E
NV0E Member ✭✭
edited April 10 in Third-Party Software
Hi everyone,
I’m happy to share that RimuSDR, the new Linux‑native software suite for FlexRadio users, is now officially available.
After extensive testing with a dedicated group of operators, the software has reached a stable, production‑ready state. The initial release includes a comprehensive feature set covering virtually all functionality operators rely on today, along with the companion tools:
  • RimuDAX — digital audio exchange
  • RimuCAT — CAT control for logging, digital modes, and automation
You can download the release, view screenshots, and read the full feature overview here:
https://rimusystems.com/rimusdr
Thank you to everyone who tested, provided feedback, and helped shape the first release. I’m looking forward to hearing how it works for you.
«1
    Congratulations Simon! I just downloaded 1.1.3 for the Raspberry Pi. I will give it a shot this evening.
  • WX7Y
    WX7Y Member ✭✭✭✭
    Great experience so far, I have not fully tested the CAT and DAX but it looks great, Kinda bothers me there are only 2 CAT ports available, Looks like a very close clone of SmartSDR in operation and settings.
    After trying to get a few CAT programs working easily and reliably on AetherSDR on Linux, I can tell you it is a very difficult task but possible and is getting better, and if the RimuDAX and RimuCAT pans out to work as good as they look it will be a game changer on Linux.
    I have ran it on Linux Ubuntu 24.04, and on my raspberry Pi5 and both run really well and graphics on the Ubuntu Linux computer are outstanding, except on the Pi5 SmartLink won't sign in and shuts down the Program.
    Good Job Simon on building something that we have waited for for more than 12 years.
    Bret WX7Y
  • NV0E
    NV0E Member ✭✭
    Bret, thank you for the detailed feedback. I’m really glad to hear RimuSDR is running well for you on both Ubuntu and the Pi5, and that the graphics performance stands out.
    CAT is still early and the current limit of two CAT port protocols is just the initial implementation. I will be expanding it soon.
    The Pi5 SmartLink crash is especially helpful. I will contact you directly to gather more information.
    And a fun bit of trivia: you were actually the very first person to purchase RimuSDR after launch. I really appreciate you jumping in right away and giving it such a thorough workout.
    Thanks again for taking the time to test it and share your impressions. It has been a long wait for Linux users, and it is great to see it running well on your systems.
  • WX7Y
    WX7Y Member ✭✭✭✭
    Simon, Please add the FDVU and FDVL modes to RimuSDR so we can use the FreeDV-FlexRadio.appimage to give us Freedv on ALL 6000 and 8000 Radios. SmartSDR has it as does AetherSDR, I have ran this for several Months and it really works well. Below is the Information Page.
    https://github.com/drowe67/freedv-gui/releases/tag/v2.2.1
    I have it running here on the same computer that I have RimuSDR on and also on my Node-red Raspberry Pi as a backup, (Only one at a time) as long as the computer is on the same network the Radio will find it.
    So please add these FreeDV modes as I use them Daily.
    Bret WX7Y
  • Joe Herreweyers
    Joe Herreweyers Member ✭✭
    I am brand new to Linux having just starting to explore it earlier this week. Will this program run efficiently under WSL. It seems to me to be a starting point as I explore Linux and the program/Apps available. It would also also seem to provide the option to run my 6700 and 8600 on the same PC and monitor cluster.
    Thank you, Joe N9EMC
  • NV0E
    NV0E Member ✭✭
    Hi Bret, I'll take a look at the FreeDV modes. It sounds quite interesting.
  • NV0E
    NV0E Member ✭✭
    Hi Joe, WSL will probably turn out to be problematic for this kind of software.
    WSL uses a NAT layer that isolates it from the host network, and that can interfere with radio discovery unless you start adding bridged‑adapter workarounds. Even then, it’s not always consistent. That alone makes it a shaky starting point.
    TX/RX audio is another issue. WSL doesn’t expose audio devices in a way that works well for low‑latency streaming, so RimuDAX is unlikely to behave correctly there. RimuCAT would be even more difficult, since WSL doesn’t provide real serial ports and its virtualized networking stack behaves differently enough that CAT bridging is likely to break.
    If you want to explore Linux, a lightweight VM or a small dual‑boot partition will give you a much smoother experience than WSL for anything involving radios, audio, or CAT. Dual‑boot in particular avoids all the virtualization quirks and gives you a clean, native environment to work with. I’ve set up a dual‑boot with Windows and Linux myself, and I find I spend most of my time in Linux now, only flipping back to Windows when I need an application that only exists there.
  • TimW
    TimW Member ✭✭
    I purchased a license yesterday and will be trying RimuSDR out on a Raspberry Pi 5 and a Linux distribution on an older HP Z2 mini. For the HP would you recommend Debian, Ubuntu, or something else?
  • NV0E
    NV0E Member ✭✭
    Hi Tim,
    RimuSDR runs equally well on both Debian 13 and Ubuntu 24.04. I personally run Ubuntu 24.04 so that's what gets tested the most. The list of tested distributions is here: https://rimusystems.com/ It's quite likely it runs on a much wider range of Debian based distributions that what we actually test on.
  • TimW
    TimW Member ✭✭
    Thanks Simon, I must have missed that list of tested distributions. Will try a couple of the others too before settling down.
  • digver
    digver Member ✭✭
    Hello!
    A quick receive check of the sdr appimage with Fedora 44 says it is Aokay. But that is only sdr, I have not tried dax or cat.
    73, digger ab3xu
  • NV0E
    NV0E Member ✭✭
    RimuSDR v1.1.5 - Release Announcement
    The v1.1.5 update for RimuSDR - Native Linux SDR for FlexRadio is now available. This release delivers major enhancements across RimuSDR, RimuCAT, and platform packaging, focusing on expanded capability, improved usability, and broader system support.
    Key Enhancements
    • RimuSDR Trial Mode — Trial mode is now available for downloads, providing evaluation access restricted to 80 m and receive‑only operation (no TX) prior to licensing.
    • FreeDV Support — Running the FreeDV FlexRadio AppImage automatically adds FDVU and FDVL slice modes to RimuSDR.
    • Quick Audio Recording/Playback — One‑click audio capture and instant playback for rapid verification and testing.
    • Sub‑Band Display Improvements — Added IARU region‑based sub‑band selections for more accurate band visualization.
    • USB Cable Menu — New menu option for USB cable configuration.
    • SmartLink Performance — Faster authentication and extended timeouts for operators on slower networks.
    • RimuCAT Protocols — Added Passthrough, N1MM Spots, Winkeyer, and ORTP (all minimally tested).
    • arm64 .deb Builds — Experimental arm64 packages now available.
    • RPM Packaging — Added RPM builds for Fedora 42, Fedora 43, Rocky 9, and Rocky 10.
    Fixes
    • RimuSDR Stability & UI — Corrected several operator‑visible issues including status‑bar alignment, profile‑based mode selection not toggling the Phone/CW panel, 1 Hz VFO drift during keyboard tuning, slice‑flag slider wheel jumps, and a multiFLEX reconnection case that could result in silent receive audio.
    • RimuDAX & RimuCAT Reliability — Resolved TX‑audio Busy‑state lockups, prevented Linux from auto‑switching audio defaults, fixed a Remote‑Audio interaction that could permanently suppress microphone audio, corrected a RimuCAT port‑deletion SIGSEGV, and fixed an API‑layer issue where the active slice was being determined incorrectly.
    I have been testing RimuSDR on my Raspberry Pi 4B and also on Windows 10. It is working great on both platforms!
    I can run RimuSDR and SmartSDR at the same time on the same computer without issue. This lets me connect to my 8600 locally in the shack and my club 6400 via SmartLink at the same time without dragging out another computer. RimuSDR has a nice feature that it keeps all of your SmartLink logins so that you don't have to re-enter your credentials when changing to a different SmartLink account. This is optional if you prefer to re-enter the information for security reasons.
  • AA0KM
    AA0KM Member ✭✭
    Amazing initial first install on R-pi 4/4gb-ram/125gb data ssd with argon40 case.
    I have R-pi 5 going to see how it does as well.
    Using Btop for cpu usage and not much Ram usage less than 600mbs out of the 4gbs.
    Processor usage adequate not too taxed on the 4-cores.
    So wondering R-pi with say lower memory like 2gb how it will perform.?
    Now with · arm64 · Raspberry Pi · Windows
    https://rimusystems.com/download
     · AppImage · Debian Packages · RPM · Installer
    Congratulations!
    ===========Fun to look at Raspberry Pi how it compares»»»»»»»»»»»»»»»»»»»>.>.>.
    • The earliest example is the Intel Core 2 Quad Q6600, released in January 2007
      • Clock speed: 2.4 GHz
      • Cores: 4
      • Architecture: Kentsfield (essentially two dual-core dies in one package)
      • November 2007 (Phenom 9500/9600, ~2.2–2.3 GHz)
      • Around 2.4 GHz level: not exactly at launch—AMD reached and slightly exceeded it in early 2008 with the Phenom 9850 (2.5 GHz)
  • Didier F6DXE
    Didier F6DXE Member ✭✭
    Installed on Linux Mint, works well on this side using the latest version.
    Thanks for all this work. A lot better than using Hamlib and nDax/nCat.
    **** (Didier) F6DXE
  • Didier F6DXE
    edited April 26
    On Linux MInt the Cat is working ok, on the DAX side, input works well but I have some problems with the output.
    RimuDAX shows signals going out but nothing out on the flex. All settings on the TRX side and Rimu seems to be ok. Is this situation already known?
    73's
    Didier F6DXE
  • K4QXX
    K4QXX Member ✭✭
    Simon did a fantastic job on this software. I have already made contacts with WSJT-X and FLdigi and been running the software for two days straight with no issues. Now just need to figure out how to get a logging program installed and sync'd.
    Simon, are you eventually going to add PGXL and TGXL support? That would be extremely helpful.
    Burch
    K4QXX
  • NV0E
    NV0E Member ✭✭
    Hi Didier,
    RimuDAX seems to be working well for everyone, and I'm not aware of any issues. If you haven't checked already, there's a WSJT-X setup guide here: https://rimusystems.com/wsjtx.
    If that doesn't help please send an email to support@rimusystems.com with your symptoms and sceenshots and we can figure out whats going on.
  • NV0E
    NV0E Member ✭✭
    Hi Burch,
    Great to hear it's all working well for you!
    I've add quite a few requests for PGXL and TGXL support. So I'm adding it to the roadmap.
  • albert
    albert Member ✭✭
    Hello NV0E,
    I switched from Windows11 to Kubuntu. I'm using the latest version of Ubuntu, 26.04.
    Do you think this will work, or do you plan to upgrade to 26.04 soon?
    Thank you for your reply.
    73 d'Albert ON5AM
  • g4ivv
    g4ivv Member ✭✭
    Hi Albert,
    I've been running RimuSDR on Ubuntu 26.04 and it is working very well for me, in fcat I think its my favourite Flex client. I think Simon will be officalliy testing 26.04 soon, but its looking good here.
    73, Jonathan
  • NV0E
    NV0E Member ✭✭
    Hi Albert,
    As Jonathan mentioned, now that Ubuntu 26.04 has been released, we’ll be adding it to the list of distributions we actively test. We already cover a wide range of environments in our RimuSDR Test Environments, but RimuSDR typically runs well on many more distributions than the Debian‑based ones we validate.
    If you’re unsure about your setup, the easiest approach is to download RimuSDR and run it in Trial mode to confirm everything works on your system.
  • Didier F6DXE
    edited May 7
    HI,
    I am curious to know if anybody using a Flex6400M (let op M version) has been successful with the DAX ouptut !
    I am very please with the way RimuCAT is working with all my programs. DAX input is working well as the microphone input but DAX output while showing signals , the flex is not sending anything, MOX is activated but no signals.
    Simon and his team has been doing a great job so far for the Linux users.
    **** F6DXE
  • NV0E
    NV0E Member ✭✭
    RimuSDR v1.1.6 / v1.1.7 – Release Announcement
    RimuSDR v1.1.6 is now available, followed immediately by v1.1.7, a targeted patch addressing two issues discovered shortly after release. Together these updates deliver significant new features, a major UI workflow improvement, and a range of polish and reliability fixes.
    RimuSDR – Native Linux SDR for FlexRadio
    Key Enhancements
    • DVK Panel : A Digital Voice Keyer panel is now integrated directly into RimuSDR.
    • MIDI Controller Support : Full MIDI controller support is now built in, including native support for the Lynovation CTR2 controller.
    • Customizable Filter Widths : Filter widths can now be customized natively within RimuSDR, with no dependency on a SmartSDR+ license.
    • Improved Slice Panel Workflow : The Audio, DSP, Mode, RIT, and DAX panels can now all remain open simultaneously, making multi-panel operation far more practical.
    • Sub-Band Display Rework : The sub-band display has been redesigned to more closely match SmartSDR+ behavior while remaining fully client-side.
    • Enhanced Diagnostics : The Diagnostics dialog now includes a complete radio feature list, making troubleshooting significantly easier.
    • Updated API Layer : The protocol layer has been aligned with FlexLib 4.2.
    Fixes
    • Slice Audio panel now sized correctly for Diversity (v1.1.7)
    • Slice Tuning flag passband z-order corrected when two slices share a frequency (v1.1.7)
    • Smoother keyboard arrow-key tuning on the Slice Tuning flag
    • Settings dialog reliability improved across distributions
    • Performance improved with large numbers of spots
    • Right side panel button states and panadapter splitter position now saved correctly
    • Panadapter splitter no longer collapses unexpectedly
    • TX Band Settings dialog displays correct columns for FLEX-6300
    • PC Audio gain value now correctly persisted in settings
    • RimuCAT : Validation added to ensure a Slice is selected before saving
    • RimuDAX : Resolved potential driver-handling edge cases
  • Jean Louis
    Jean Louis Member
    Hello Simon,
    Thank you for your work on RimuSDR and your quick response in fixing the bugs.
    Sincerely,
    73 J.Louis
  • Didier F6DXE
    Thanks to Simon for the support.
    The problem with the DAX tx , for the FLEX6400M, I had has been solved.
    For the M version of the Flex, starting RimuSDR is not necessary, RimuDAX and RimuCAT are working well alone.
    **** F6DXE
  • NV0E
    NV0E Member ✭✭
    Thanks Jean Louis, I’m glad everything is running well on your 6300. And Didier, thanks for the follow‑up on the 6400M. I really appreciate you both taking the time to test things and share your results. It helps make the whole application better for everyone.
  • Erik Carling EI4KF
    Len KD0RC (and by the way, thank you for your comments re award!): ok, RimuSDR installed in Windows.
    Initial impressions: AetherSDR has TCI that I prefer. With Rimu in Windows, limited to Smart DAX & CAT.
    Rimu does not have the features of AetherSDR though it is early days so wait and see on that. Disappointing right now though given it costs money whilst AetherSDR does not.
    Big plus point: although it copies the SmartSDR UI, in my view long overdue for an overhaul, the UI in RSDR for me is the best of the three (SSDR, AetherSDR, RimuSDR). Everything is very clear, easily read, an improvement on SSDR and certainly not the ink blot that the AetherSDR UI looks like.
    It is less demanding on computer resources than AetherSDR without any obvious programming errors. CPU and memory usage remained stable over the hour of usage I put it to. On the other hand, for some reason the rendering of the panorama and waterfall are less smooth than SSDR / AetherSDR. Both look clunky and I haven't been able to improve it.
    Of the three, my current preferred choice of SDR software to run with my 8400M is ……..(drum roll)….
    SmartSDR.
    I'll never live it down. But I'll be keeping an eye out for version updates for Aether & Rimu as they both have potential.
    Thanks Len for alerting me to it.
  • NV0E
    NV0E Member ✭✭
    Erik, first off, congratulations again on your Elmer of the Year award. Very well deserved.
    And thank you for taking the time to write up such a detailed set of first impressions. I really appreciate the balanced notes on UI clarity, performance, and the areas where things did not land for you on Windows.
    I will follow up with a couple of questions so I can dig into the waterfall and panadapter smoothness you saw and better understand your setup. Thanks again for giving RimuSDR a solid test run.
  • Roger
    Roger Member ✭✭
    After reading the entire six pages of this posting and using AetherSDR I can't come up with a good reason to try RimuSDR.
    AetherSDR seems to have a lot going for it:
    1.) It's free and open-source software - Any user who's inclined and can even vibe code using Claude or any other AI agent can make changes and submit those changes for inclusion in the main branch of AetherSDR. With Claude and other AI tools you don't even need to be a "programmer" any more to customize your preferred SDR client. All you need is a good idea.
    2.) It's written in Qt6 so it's write once and run (almost) everywhere. Right now, Linux, Mac and Windows are supported. I don't suspect it will be long before we see Android and iOS support.
    With the passing of Elwood Downey, WB0OEW and the demise of Hamclock I'm very hesitant to become invested in another single author closed source project.
    I've even wondered how long SmartSDR for iOS and Mac by marcus DL8MRE will survive as AetherSDR matures.
