Can MAX power limit be set on PGXL/
ChrisNia
Can a max power be set for PGXL in the Flex ecosystem? FLEX pGXL produces different power outputs with same drive depending on band.
Create a profile for each band on which you have the appropriate power of the radio, which is 10 watts for 20 meters. It’s likely that 8 watts on another band will produce the same power. This is how I typically resolve this issue.
Thank you
In Flex SmartSDR, or Maestro, go into TX Band Settings and set power out per band.
Thank you
- 691 The Flea Market
- 197 SmartSDR+
- 462 SmartSDR for Mac
- 114 Aurora
- 980 Genius Products
- 359 Tuner Genius XL
- 136 Antenna Genius
- 323 Shack Infrastructure
- 228 Networking
