Time problem since the start of BST Uk
Then came BST, Now no one talks to me, Time on mac is different to time on the SDRMAC Software.
Any help would be gratefully received please
All the best from Alan
Hello Alan -
This sounds like a time setting issue on your Mac. I’d recommend you visit: and check that everything is set up correctly.
If the problem persists and your settings appear correct, you might try a simple uninstall/re-install of Mac SSDR.
Good luck!
I do not think a reinstall will help. The MAC has changed to BST as you say Alan but as with ham radio software in general, the expected value is UTC. Merely turn off BST auto-adjustment so that it is aligned with SDRMAC.
Good Afternoon Bill and Erik,
Thank you for coming back to me, I have read so much on time its doing my head in, what i read is it does not matter about BST/UTC because the FT8 only looks at the position of 0-59 seconds, how does that go along with your thinking.
All the best from Alan & Thank you0 -
I set the IMAC 2020 Time zone to UTC +00:00 London, the IMAC did not complain about my input, but it fell in line with hours sometimes Min's but the difference between IMAC and SMARTSDR was 20seconds
Totally useless no contacts.
All the best from Alan0 -
Hello Alan,
Do you have your Mac configured to automatically set its time from the internet?
In Settings, General→Date & Time, here's how I have mine and as you can see the time is the same as that indicated in SmartSDR for Mac (allowing for summer time):
As long as the Mac is getting its time from an internet NTP server (make sure the automatic setting is on) I can't really see how it could be 20 seconds out?
Hope that helps,
73 Jonathan G4IVV0 -
Good Afternoon Jonathan, as you have it displayed in your picture, is how i had it set, but there was 1 hour difference between IMAC and ft8 software which is built in smartsdr for the mac
If i change time zone to UTC+ 00:00 London, then there is 20seconds difference
Yes, you must be disabling the NTP time correction when you manually set the timezone. For FT8 you really have to have the NTP switched on so that your Mac clock is within a second (the 1 hour summer time offset doesn't matter, SmartSDR is just displaying UTC).
If you turn on the automatic time setting (NTP) then you should be able to make QSOs again.
I have set it back to the way you have in Jonathan, as per your picture, still cant contact anyone.
Good Morning Everyone, I came across this website a greate help, and it does not matter what OS you have
https://time.is/
Tells you everything about your time on your OS, now i am moving forward
Good luck to all0 -
I love time.is! Whenever I set watches or (non-automatic) clocks, I browse to time.is on my phone.
For everything computer-related, I always use NTP and ensure my computers all have the same idea of what the time is. I run 8 servers, and apparently have 43 clients on my home-network (!), and it's imperative that they all share a common understanding of what time it is. NTP does that, and no device is left un-sync'd.
I'm happy to read that you're moving forward.
NTP and synchronization of time is important.
Well moving forward yes, now I hit a big wall, If I put out a CQ, people come back and answer me, but my system FT8 goes not carry on the conversation
After deleting Mac Smartsdr and its libraries, and then re install Smartsdr,
Then everything on FT8 worked perfect.1 -
Well, for FT8 on SmartSDR, I use Meinberg NTP server. Always accurate.
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
