Time problem since the start of BST Uk
I have had me Flex 8600M for a few months, but did nothing with it, until I brought S/H iMac 2020, running Tahoe 3, Setup the FT8 (Built in) and logbook connected to QRZ, wonderful works perfect no problems no grief.
Then came BST, Now no one talks to me, Time on mac is different to time on the SDRMAC Software.
Any help would be gratefully received please
All the best from Alan
  • K3CDY
    K3CDY Member ✭✭✭
    Hello Alan -
    This sounds like a time setting issue on your Mac. I’d recommend you visit: https://support.apple.com/guide/mac-help/change-date-time-settings-mchlp1124/mac and check that everything is set up correctly.
    If the problem persists and your settings appear correct, you might try a simple uninstall/re-install of Mac SSDR.
    Good luck!
  • Erik Carling EI4KF
    I do not think a reinstall will help. The MAC has changed to BST as you say Alan but as with ham radio software in general, the expected value is UTC. Merely turn off BST auto-adjustment so that it is aligned with SDRMAC.
  • g0wda
    g0wda Member
    Good Afternoon Bill and Erik,
    Thank you for coming back to me, I have read so much on time its doing my head in, what i read is it does not matter about BST/UTC because the FT8 only looks at the position of 0-59 seconds, how does that go along with your thinking.
    All the best from Alan & Thank you
  • g0wda
    g0wda Member
    I set the IMAC 2020 Time zone to UTC +00:00 London, the IMAC did not complain about my input, but it fell in line with hours sometimes Min's but the difference between IMAC and SMARTSDR was 20seconds
    Totally useless no contacts.
  • g4ivv
    g4ivv Member ✭✭
    Hello Alan,
    Do you have your Mac configured to automatically set its time from the internet?
    In Settings, General→Date & Time, here's how I have mine and as you can see the time is the same as that indicated in SmartSDR for Mac (allowing for summer time):
    As long as the Mac is getting its time from an internet NTP server (make sure the automatic setting is on) I can't really see how it could be 20 seconds out?
    Hope that helps,
    73 Jonathan G4IVV
  • g0wda
    g0wda Member
    Good Afternoon Jonathan, as you have it displayed in your picture, is how i had it set, but there was 1 hour difference between IMAC and ft8 software which is built in smartsdr for the mac
    If i change time zone to UTC+ 00:00 London, then there is 20seconds difference
  • g4ivv
    g4ivv Member ✭✭
    Yes, you must be disabling the NTP time correction when you manually set the timezone. For FT8 you really have to have the NTP switched on so that your Mac clock is within a second (the 1 hour summer time offset doesn't matter, SmartSDR is just displaying UTC).
    If you turn on the automatic time setting (NTP) then you should be able to make QSOs again.
  • g0wda
    g0wda Member
    I have set it back to the way you have in Jonathan, as per your picture, still cant contact anyone.
