Power Settings with Global Profiles
When you setup global profile, is the power setting selected not saved too? When I change to a different profile, it seems the power setting stays at what I was on prior to changing profiles.
Correct. And there are different transmit profiles assigned to each mode group.
This 'draft' document might help. I was just working on it.
We have a brand new SmartSDR manual (just saying that as I was reviewing it).
The details are in section 19.
Power is part of the TX Profile.
Thanks Mike, I will get this printed off.
To confirm I understand correctly, when creating a Global profile, the power setting does not save, the power setting only saves when creating a Transmit profile?
Understood, thanks again Mike
Brett W5BLF
There are a number of 'issues' with that draft. So, I am going to delete it.
The Global profile loads the associated Transmit profile.
According to our expert, @David Decoons, wo2x, this is the way:
How to Build Global Profiles the Right Way
The best approach is to work from the bottom up, one band at a time. Here’s the method:
- Step 1 — Start on your lowest band.
- Configure your Mic Profile for the operating mode you are setting up (SSB, CW, or Digital)
- Select the correct transmit antenna and configure its Transmit Profile
- Dial in all your receiver settings: panadapter position, slice frequency, bandwidth, AGC-T, and any DSP settings
- Save the Global Profile with a meaningful name (e.g. “SSB”)
- Step 2 — Move up one band.
- Adjust all your RX settings for that band — frequency, panadapter, AGC-T, filters
- Save the same Global Profile again — that band’s configuration is added in
- Step 3 — Repeat for every band you operate.
- Work up through all your bands, saving the same profile each time
- Each save adds that band’s receiver configuration to the profile without disturbing the others
- Step 4 — Repeat the entire process for each operating mode.
- Build a separate Global Profile for SSB, CW, and Digital
- Each profile will have its own complete band-by-band RX settings and the correct Mic and Transmit Profile associations for that mode
0 - Step 1 — Start on your lowest band.
- 390 Community Topics
- 662 The Flea Market
- 440 SmartSDR for Mac
- 55 Aurora
- 971 Maestro
- 946 Genius Products
- 308 Shack Infrastructure
- 216 Networking
