Genius connection to yaesu G-1000DXA
wp3a00
wp3a00 Member ✭✭
I need to know which wire or pins I have to connect in my Rotor genius using my Yaesu G-1000DXA rotor I tried to use 4 and 5 and it doesn't work any other idea or which one to use I think they are only 2 wire or am I missing some step?
Best Answers
    Answer ✓
    Please reach out to 403A directly.
    www.403A.com
  • Mike VE3CKO
    Mike VE3CKO Member ✭✭✭
    Answer ✓
    OPPS, was looking at something else, it is pins 5 and 4, not 5 and 3
  • wp3a00
    wp3a00 Member ✭✭
    Yes, I have already done it, but there is something that is still not being explained clearly in the instructions. I have followed it as they are sent to me and I cannot get the Rotor Genius to work. I have a feeling that there must be a voltage next to these 2 pins and That's what I'll try to find out today...
    We do not sell the RG and have limited experience with them.
    As 403A is the designer of the RG, you will need to continue to follow up with them.
  • wp3a00
    wp3a00 Member ✭✭
    Ok Mike It only mentions it in case someone in the community does not have the RG configured with the yaesu G-1000 rotor but I continue to check with 4O3A for more information , thank you for you input...
  • Mike VE3CKO
    edited January 2022
    At one time I looked into the Rotor Genius, do not own one but my understanding is that it just supplies the DC voltage to the rotator. That being the case, you would need to look at the schematic of the 1000DXA to determine what pinouts are for the rotator motor. I do have several 1000DXA and on page 16 of the manual is a the connection diagram showing the motor is on pins 3 and 5 of the rotator. Hope that helps you.
  • wp3a00
    wp3a00 Member ✭✭
    Perfect if I think that the pins I was using were not the correct ones according to what they sent me as 4 and 5 today I will try those pins 3 and 5 and see how everything works, thanks for your help
  • wp3a00
    wp3a00 Member ✭✭
    Yes I see too is 4 and 5 but idont why not working....but i check again today...
  • Mike VE3CKO
    edited January 2022
    Have you tested with the Yaesu control box to confirm the rotator functions normally first ? Maybe the rotator is at one it's limits, and if the rotor genius is sending voltage at the polarity the motor will not engage. Try reversing, 5 - 4 to 4 - 5.
  • wp3a00
    wp3a00 Member ✭✭
    Yes is working perfect I test many time yesterday and today with the Yaesu control ....yes I use both pins in different area too ...
  • sschrack
    sschrack Member ✭✭
    Hello wp3a00,
    Did you find a solution to get the Rotator Genius working with your Yeasu 1000SDX? I have the same rotator and considering replacing my older controller with with the RG. Can you share your results and solution and your experience with RG?
    73 Steve N3MX
  • F4BPO
    F4BPO Member ✭✭
    Hi All,
    I reply on this one even if it is 3 years old.
    I have just bought a Rotator Genius and can easily turn both rotator (one with small 12v dc motor for the Buddihex) and the Yaesu G1000 DXC by wiring the pin 4 and 5. Does anyone know how can I make use of the brake and also how to change the speed (increase the speed) of the Yaesu ? shall I apply more than 12v as I know it can range from 12v to 22v.
  • I know this is a really old thread and that we should contact Ranko (already on it), but I plan to buy a Yaesu G1000DXC rotator and have a RG I want to use with it. Is any of you already doing it?
    73, Santiago
  • F4BPO
    F4BPO Member ✭✭
    Yes I am doing everyday pin 4 and 5 to be plugged on RG and it works fine. 18v is quite fast while 12v is quite slow.
  • @F4BPO are you able to send me pictures of your dips switch’s? The N/C specifically. I think the Set A it’s alright: all off except 8 for the G-1000.
    BUt I don’t know what mine is not working.
    73, Santiago
  • 4O3A Signature
    4O3A Signature Member ✭✭
    Santiago, manual is on https://4o3a.com/support/downloads
    In manual, page 9 all is described for DC driven rotors. Very simple wiring. I sent you an email.
    Ranko
  • Update for the group.
    Following @F4BPO experience I decided to use 27v power supply and following Ranko´s instructions I got my Rotator Genius working with my Yaesu G-1000 rotator.
    It has some hiccups from time to time, but its a network issue (not a RG issue), so I´m checking my network and changing all cables with new ones and doing some ferrite work in the shack. Manually it works flawlessly.
    Thanks both for taking the time to help.
    73, Santiago
    HI8O - KB8SM
  • F4BPO
    F4BPO Member ✭✭
    HI Santiago,
    Sorry did not see your messages earlier.
    I see you got things sorted out.
    So finally you use a 27v at 75% to drive the G1000 ? or at 50% ?
    I am using at 14v right now but I feel like I should increase the voltage, I am gonna hook it up again to my 24v at 75%.
  • Hi. I use a 27v at 75%, and it runs quite fast. Quick and smooth. For 75% its DIP 7 ON and DIP 8 OFF. Im not using the soft start (DIP 5).
    I´ve been running it for 2 weeks now and its fine.
    73, Santiago
