Interfacing microHam Station Master to Tuner Genius
I'm trying to interface my microHam Station Master, which is connected to my FTdx101d, to my TGXL. Because I already have the Station Masters PA output port supplying BCD band data to my amp, I thought I could use pin5 (CI-V out) connected to the TGXL. I'd like to supply the TGXL with actual freq info as opposed to BCD so that it would fully utilize it's tuning solutions that are stored in memory. In theory this is supposed to work but the TGXL panel and utility so not recognize the CI-V data and remains in RF SENSE mode. I've tried this on both Ports A &B without success. Does anyone have any ideas?
Marv K7IU
  • K7IU_Marv
    K7IU_Marv Member ✭✭
    Turns out my idea worked. I was able to connect the CI-V data out from the Station Master to the CI-V in port on the TGXL. I also used the PTT line from the SM as well.
