Mastro A will not light up
I have a problem with a Maestro A the screen will light but the Mastro will not all the light on the maestro are dead it is like that part is not powered up can it be fixed did it lose the program .
Thanks Mike
    Make sure that the power cable is 100% plugged in on the back and that it is plugged into the wall.
    If you still have an issue, open a support ticket please.
    It can't loose its program. :)
  • falcon505
    falcon505 Member ✭✭
    I am getting power to the board it was working just quit will open a support ticket.
    Thanks kd8nni mike
  • falcon505
    falcon505 Member ✭✭
    Were do fill out a support ticket can;t find it.
    Thanks mike
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    At top of this page:
