DAX Driver Error on NEW Windows 10 (or 11) installation
PA2TA
PA2TA Member ✭✭
edited June 2022 in DAX
This is about a first installation of SmartSDR on a NEW Windows 10 machine, so it is not about changed names of the DAX Audio devices after an update or upgrade of Windows.
A lot has been said and written about DAX Errors, but I couldn't find anything related to this problem.
TLDR;
If you get the "DAX Driver Error" message after installing SmartSDR on a CLEAN Windows 10 (or later) installation, first check the "Memory Integrity" setting under "Core Isolation". If it is enabled, disable it. The DAX drivers do not need to be reinstalled, a reboot of the machine is sufficient.
The long story:
My brand new HP Elitebook laptop is equipped with Windows 10 Pro, but this may also apply to new installations of the Home version or Windows 11 (Pro or Home).
After uninstalling the inevitable bloatware, the next task was to install SmartSDR. Everything went fine, but after starting SmartSDR the message "DAX Driver Error" appeared on the screen.
This was certainly not the first time I installed SmartSDR, it has been running flawlessly for years on multiple laptops and PCs running Windows 7, 10 and 11, both the Home and Pro versions. But it was the first time I encountered this problem. Strange, why does it run without problems on all those other machines and not on this new laptop?
In device manager the DAX drivers showed the error message:
Unable to load the device driver for this device into memory. The driver may be corrupted or missing. (Code 39)
{Invalid Image}
%hs is not suitable for Windows or it contains an error. Try installing the program again using the original installation media or contact your system administrator or software vendor for assistance. Error status 0x
Even after uninstalling and reinstalling the drivers several times, following the procedure described by Tim - https://helpdesk.flexradio.com/hc/en-us/articles/204017069-How-to-Manually-Re-Install-DAX Drivers - the problem persisted.
I spent two days and one night trying to solve the problem by removing more software from HP and searching the Flexradio forum and the rest of the internet, all to no avail.
Until I ran into the "Core Isolation" - "Memory Integrity" settings. After disabling "Memory Integrity", followed by a machine reboot, miraculously the DAX devices appeared under "Audio Input and Output " in "Device Manager" , and under "Sound, video and game controllers" the DAX drivers no longer showed errors.
Conclusion: after disabling "Memory Integrity" the DAX Drivers are correctly loaded into memory. The disadvantage is that "Memory Integrity" cannot be re-enabled afterwards because incompatible drivers are now present.
Learn more about Device Security and Core Isolation here: https://support.microsoft.com/en-us/windows/device-protection-in-windows-security-afa11526-de57-b1c5-599f-3a4c6a61c5e2
The reason it worked fine on all other machines is probably because the other machines are all a bit older and the "Core Isolation" and "Memory Integrity" settings only appear in later versions/updates of Windows.
On one of the laptops, recently migrated from Windows 10 to Windows 11, the "Core Isolation" function is not present, on another it is present but disabled. It turns out that "Memory Integrity" is turned off by default for migrations from Windows 10 to 11.
Maybe not a top priority, but it seems to me that Flexradio has a job to do here to eventually make the DAX drivers compatible (but I also realize that the drivers are probably deeply embedded in Windows and that this is not just a piece of cake ).
  • Larry Benoit
    Larry Benoit Member ✭✭
    Been there, done that with three different Microsoft Surface Laptop 4 computers running Windows 10 or 11. As you note, this is happening with newer Windows PCs that have the necessary hardware to support the latest Windows 10/11Device Security features.
    Flex support advised that another re-write of the DAX drivers is forthcoming to address this security defect and other longstanding bugs. As is customary, no target date was given.
    Larry KB1VFU
  • johnn1jm
    johnn1jm Member ✭✭✭
    I'm wondering if I should turn memory integrity off or wait for Flex. Everything is okay on my Dell tower(older).
    John N1JM
  • David Decoons, wo2x
    Hi John
    If everything, including DAX, is working on your Dell tower then I would not change the current setting. The old adage, “Why fix it if it isn’t broke?”
    Since your computer is older hardware may be why you are not experiencing the problem.
    Have fun with your Flex!
  • johnn1jm
    johnn1jm Member ✭✭✭
    edited August 2022
    Yes, I installed SSDR on a new Lenovo laptop with Windows 11 Pro and everything worked except DAX. I think I will hold off.
    73, John N1JM
  • Manfred
    Manfred Member
    edited September 2022
    same trouble: Where is the solution for it? I don't like to work with a unsafe PC only to play a radio! Where are updates and features? Hey Flex are you still there? I'm going to lose my confidence
    in these radios. No more progression and this security error is a lot to handle for me.
    73, Manfred HB9FLU
  • Thanks for posting it! We run exactly into this problem with one of the remote access users and your hint solved it here as well. Brand new PC with Win10.
    73 Holger
  • kn6leh
    kn6leh Member
    I just got a 6400 (non-M) and was excited to get things set up, only to discover that I have to disable effective security on my PC to make it work? Incredibly disappointing. This issue seems that it's been open for a while. Any news from FlexRadio on modernizing the driver?
  • W5XZ - dan
    W5XZ - dan Member ✭✭
    edited December 2023
    I too am having this problem with a new-to-me lenovo 540p laptop ( i7 ); re-installing the dax drivers didn't help, and Memory Integrity is turned off...just beginning remote work with s/n 15 6500...dax needs to play for jtdx to work..
    The SmartSDR DAX v3.5.9.2...control panel says tx stream 'Driver Error'...
    73 & HNY boys, w5xz, dan
  • WX7Y
    WX7Y Member ✭✭✭✭
    I just went through this yesterday and with the "Memory integrity" set to off, I just had to reinstall it using Higher privileges (administrator) and it installed fine and ran normally after a reboot.
    I hope you get it to install on the Lenovo
  • Gord-VA7GP
    Gord-VA7GP Member ✭✭✭
    @kn6leh
    I'm with you - I don't want to disable security enhancements. Microsoft has taken a ton of heat for ~decades~ and when they finally come through with reasonable enhancements, I don't want to turn those off!!!
    I'm also about to set up some a couple of ham-dedicated Win11 Pro machines, and disabling this will be a SmartSDR showstopper
  • Bill NE1B
    Bill NE1B Member ✭✭✭
    Any updates on the Core Isoation Memory Integrity DAX drivers? Is it in SSDR Ver. 3.7?
    de Bill, NE1B
  • Bill WW5M
    Bill WW5M Member ✭✭
    Gentlemen,
    I have a brand new Dell Inspirion 16 laptop with Windows 11 pro. I getting the same DAX error as noted by everyone else. I would like to able to use this machine for remote access for my Flex 6600's (2). I am well invested in the Flex gear - 2 - 6600's, Power genuis, Tuner genuis, 2 - 8x2 antenna genuis, with a new Maestro C on the way. I sure hope to see some answers soon to this!,
    Thanks and 73,
    Bill WW5M
  • rwood90
    rwood90 Member, Unconfirmed
    my issue is with same drivers but with getting the memory protection turned on. I have searched for the four driver files listed in screen shot, not found.
    I have run regedit as admin, with intent to delete anything entries that contained said file names.... nothing.
    I have run device manager, view hidden devices on - nothing.
    This evening reset Windows, a painful process of reloading everything.
    I seem unable to find a way to **** Windows impression that these four drivers exist. The computer in question is no longer used with FLEX but the drivers aren't there but windows thinks it is...
  • New compuer, new Win11 installation, Memory integrity off, still DAX driver error…
    Richard IS0JHQ
  • W5NE
    W5NE Member ✭✭
    Flex it is time to correct this DAX error problem, as more of us are coerced into to using Win 11 the level of concern increases. Disabling a security feature (memory integrity) is not a solution.
    Selling software that indirectly puts the customer at risk is not the "Flex Way"
    Please reply to this post and tell us what you have done so far and the expected time to resolution.
    Alex W5NE
  • Ken Golubski
    Ken Golubski Member ✭✭
    Windows 11. Can't use DAX or wsjtx…….sad
  • PhilM
    PhilM Member ✭✭
    I just installed SMARTSDR (V3.9.18) on windows 11 pro for the first time and received the memory error and had to disable memory integrity. So it appears the DAX drivers have not been rewritten to support the higher level of security in windows 10 & 11.
    Phil NC3S
  • jan
    jan Member ✭✭
    it,s now 27-09-2025 / 09-27-2025 smartsdr v3.10.10 , Windows 11 Home v 23H2
    i disable memory integrity. still it do not work !!!
    flex do you work and get us a easy fix we are now 3 years further and still nothing. ???
    flexradio 6400 atu
  • I cannot understand why Flexradio does not give any reply to all these reclamations!
    DAX Driver Error (Memory Intergrity) still occurs with a new ASUS Vivobook WIN11. 25H2
    It works with Memory Integrity disabled!
    HB9ASV Peter
  • Chris WX7V
    Chris WX7V Member ✭✭
    I'm getting the Driver Errors since this last weekends windows security update. I've manually uninstalled and reinstalled the drivers several times. I've had a help desk ticket opened 4+ days. Core Isolation (Memory Integrity) is off and has been off for a few years since this was reported in 2022.
    Short of trying a fresh install, does anyone have any other tips or tricks to try?
    Happens with the Maestro connected, and with SmartSDR 4.1.5 running locally with the radio.
    Chris de WX7V
  • WX7Y
    WX7Y Member ✭✭✭✭
    you should do a help desk ticket for assistance,
    I had this problem not long ago and even with the Help desk's help we were NOT able to get it fixed so I having a full windows backup 2 months old I reloaded my hard drive and ran the Updates that needed to be done manually and got my system back up, SO this CAN be a hair puller for sure and hopefully you won't have to resort to what I had to do and the FLEX guys can help you out.
