TX High Cut For FM
Hi everyone,
I am exploring 10m FM on my 8400 and I would like to setup a really nice rag chew audio for FM QSOs. I am confused about how to set the TX High Cut in SmartSDR though. FM has a TX bandwidth of 16K, so what would be the maximum number I can use for the high cut on FM?
On SSB the norm is 3K. So, for 3K on SSB I simply set the high cut to 3K. But FM is not SSB and I have the feeling that I shouldn’t be setting the FM high cut to 16K!
Also, I read that using anything other than the processor set to normal is not a good idea as it will introduce distortion in the audio. Is that true?
Any suggestions gratefully received.
Thank you,
David
Best Answers
Hi David, I just leave the TX bandwidth the same for FM that I use for SSB and get good results.
Yes, turn off the processor when in FM. I got reports of terrible audio on my local 2 meter repeater (using a transverter). I turned off the processor and got great audio reports again. I turn it off, not just set it to normal.
Thank you Len. I appreciate the information. David
One of the side benefits of FM is that the Low audio frequencies don't increase transmit power requirements like AM/SSB. Might sound better (natural) if the low frequencies are allowed to pass through the EQ.
Thank you John. I have tried to make the audio EQ as nice as possible using the FDX feature in SmartSDR.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 146 Amateur Radio Interests
