KD0RC Flexicraft Utility
FlexiCraft Utility V1.10 is now available on GitHub:
As a reminder, since this thread does not get a lot of activity:
Flex 6000/8000/Aurora radio utility to provide control over Flex output power when using an Elecraft KPA 500 amplifier.
The primary function of this utility is to change the output of the Flex so that it does not overdrive an Elecraft KPA 500. It provides 10 settings per band; one for each mode with and without the amp.
The utility also provides control for the KPA 500 and KAT 500. This makes managing the amp and tuner very easy, especially when operating remotely.
- ****************************** Changelog ********************************
- V1.10
- Fixed issue where SDC adjusting the AGC-T caused the RF Power to match the value on the power tab
- Fixed issue where radio events are occasionally missed at startup
If you use SDC and have it set to update your AGC-T automagically, it was causing FlexiCraft to go back to the saved power setting. I had a misplaced statement that set the power level on any slice change event. I fixed my long-standing bug and now the FlexiCraft Utility works well with SDC.
Be sure to uninstall the previous version before installing this one. Use the Windows Settings, Apps & features screen to do the uninstall, do not delete any folders or registry entries.
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
