SmartSDR v4 – Noise Mitigation Quick Reference
$200/year for the new noise reduction features that don't work or don't make a real difference is a lot of money.
They should work on a real noise reduction feature.
I'm not satisfied with what I paid for and received from the subscription.RM NOISE work 1000% better that your new features and its free!
Mike, Yes, It was fixed/changed. The NR Slider has been (Removed). I personally liked it better when it was adjustable. I guess it's never going to return in future releases, am I correct to assume that?
Could not stand 4.1.5 any longer, went back to 3.10.15 and now I have control of my radio. Paid for the upgrade that I will never use. I doubt Flex will give us back control with the slide bars until they do I will stay with V3.10.15 or move on to another brand when my Flex dies.
Mike, K6ODI2 -
Hi MikeM, I hear ya! I hope they give us the choice of Manual / Auto control of the slider(s) in a future release! Hopefully someone is listening… 🤔73, Tim
I was having a lot of odd problems with V4. I had to do a factory reset which I never had to do before. Other oddities like the Tune mode not transmitting any power, until I reloaded SmartSDR. Sometimes I would have to reboot the computer or power cycle the radio. IOS software isn't working like it should. I went ahead and followed MikeM's advice and reverted back to V3.10.15. I also use the NB slider under certain circumstances to limit the watery sound that comes with audio processing. Things appear to be back to normal. Maybe V4 was a little to ambitious. 73's Rick…
Hi Rick,
Sorry to hear about your issues. I've had some weird ones too going back to about v3.9. Tim, Eric and Dave have all taken swings at them over many months of an open ticket.
I'm not challenging your experience at all. But just as another data point mine has been things steadily improving with the largest improvement at the latest version, v4.1.5. And I'm finding the new features, at least those accessible to my 6700 all pretty great. Many others are reporting the same.
Keep in mind Flex's new s/w-f/w approach depends on feedback and iteration. We're only at (basically) the initial pass at v4 at this point. They've already stated they're adding back sliders with a new "slider panel" in v4.2 and who knows what else will be improved. Maybe they'll even finally complete the long promised APD sourced from the amp, not just within the radio. I feel like we need to give their new system a chance to work.
GL Russ KR6W
3 -
I also got fed up with V4.1.5 went back to V3.10.15 and my radio is a lot quieter and I have control.
Richard WH6S1 -
Richard, what do you mean by quieter? Can you expand on what you are hearing and maybe a before and after video so others can see what you are seeing?
What do you mean by control?
Mike, The audio on v4.1.5 is very distorted, watery, fatiguing audio hard to listen to for very long . I have tried a combination of the filters. I couldn't never get the audio to sound natural. After I switched back to v3.10.15 I used 1 or 2 TNF filters along with the NR and AGC to help remove unwanted noise within the band width helped to finish making the signal sound the way I wanted to hear it. I now enjoy doing SSB again. I do not have any recordings of the V4.1.5 audio to send you. I don't think I will go back to V4.1.5 it is to much of a pain to go thru 3 to 4 resets to get the radio working again. I sorry I can't describe the audio conditions better for you. All prior years I never felt the new updates or versions were a waste of money. I really like the manual TNF because I can't immediately get rid of the interference. In the newest version the audio fads in and out.
Richard WH6S1 -
SLIDERS…This is the way. Make it happen.
@Richard WH6S There is something fundamentally wrong with the radio then as 4.1.5 should be as good or better then 3.10.15. It is a hearable difference. Usually, when someone tells me this, the AGC-T is set way too high. Mine never goes above 30 but that is based on Preamp settings as well.
It would great if you shared screen shots of how SmartSDR is configured, (preamps, agc-t, etc) and a video as there are many ways to mess up the receiver.
The fact you have to do 3 or 4 resets tells me that radio needs service to get it resolved.
You need to open a support ticket.
It is a "hearable"? difference … What mode are you using? As a 100% CW op I can confirm that the V4 non-slider fixed NR is not better (not effective at all) than V3. Flex 6400 > I primarily run at 250 BW, AGC T @ 65 with the EQ Gains as follows:
250 -6 / 500 -9 / 1K -6
Is there a CW Op at Flex who can compare the two versions side by side?
Thanks, Tim WY1U
It would be appropriate for Flex to make a demonstration video. Because I also don't notice any difference in CW mode, while before version 4 I had excellent benefits with the variable NR.
Part of the reason I have not made any videos on noise mitigation is mostly due to the fact that I run a rural HF station that really doesn't have much noise.
It's not a criticism. But Flex should do it. If many OMs don't notice any benefits, there must be some problems compared to previous upgrade versions.
Michael Walker
"Part of the reason I have not made any videos on noise mitigation is mostly due to the fact that I run a rural HF station that really doesn't have much noise."
Surely there is someone else in the Flex team, that has noise that can make videos. I would like RNN noise explained either through video or some other way
I called on Flex to facilitate a smooth transition for users to V4 regarding DSP by means of instructional video(s) soon after paying for, unwisely as it turns out, and installing SSDR+ and finding that the new features do not work and the existing ones are better in V3. I was prepared to allow for a misunderstanding on my part but with SliderMaster and FRStack providing the all important means of adjusting levels and still not being able to effect useful DSP functions, I now seriously doubt any video will actually help. What does not work cannot be shown otherwise in any video. What is required, especially as these functions were paid for, is remedial work on the software by Flex to put matters right.
Erik, have you actually used FRStack ( latest version) with SmartSDR version 4? I have used it's DSP sliders with two different radios. A 6600 running version 4.1.5 Basic and a AU-520M running version 4.1.5 Early Access. I have found the adjustment sliders in FRStack to make a huge difference. It makes receive audio sound like full quieting FM when adjusted properly. Even the ANF that I found in version 3.x and earlier that didn't work well, works like it should. While a video showing how to use the DSP functions in SmartSDR would be nice, adjustments that work in one user's situation may not work well in other user's environment. It takes experimenting with the adjustment sliders in FRSack to find the sweet spot for your unique situation. If you haven't done so, download the latest version of FRStack and give it a try. You might be surprised how much of a difference it makes.
I use FRStack daily. It is a great piece of software and a credit to the attempts to provide users with what Flex do not. But unfortunately I am not one of the minority who have effective DSP functions even with the sliders.
Ah, I think this thread explains where the APF slider went in v4. It is still possible to adjust APF width using the FlexControl. Would be great to have this slider back.
Regarding " Usually, when someone tells me this, the AGC-T is set way too high. Mine never goes above 30 but that is based on Preamp settings as well" - I have so much to say about AGC-T and I did many times.
About Noise features - AGC should not affect any noise reduction!
About AGC-T
AGC-T - is a Manual/Automatic feature. I never touched AGC on my previously owned Yaesu radio and it worked 100% to bring up weak signals and lower loud signals to a non painful level. I talked to Steve several times about loud signals jump to my frequency "****" my ears when I am trying to pull in a weak signal. Not much can be done here, suggestion was to reduce PC audio level, but it does not help to both weak and loud station. Bottom line AGC does not work for the loud stations, neither on 6600 previosly owned or on 8600. I can make a video if Flex would ask, but they can easily test it.
I wish Flex eventually implement REAL AUTO AGC. It is a nonsense to adjust it constantly on every band, in the morning/afternoon/evening/antenna to the north/ antenna to the west and so on. Who has time for it in the contests?
You call it a Powerful feature, I call it Manual adjustment that have a many chances to be improperly adjusted.
When I run in contest with high speed, turn my antenna different directions I do not need/want/spend time to go to an empty frequency, adjust AGC-T and than RUN.
Sorry, this thread is about Noise mitigation. But any time I hear about improper AGC-T adjustment it's make me to put a request to make it as real Automatic Gain Control - turn it ON and forget.
Hope one day it will change.
KN7K
- 384 Community Topics
- 649 The Flea Market
- 149 SmartSDR+
- 263 SmartSDR CAT
- 287 FLEX-8000 Signature Series
- 961 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 142 Amateur Radio Interests
