Fixed Mode for Slice Flag Needed as well as...
John
N2KBE
John…I don't have an M model so this may not apply.
In SSDR on the bottom left of the display there are two icons the look like magnifying glasses. If you click/tap the one with the + symbol the frequency will center on the display.
That is true on both the M Model and SmartSDR, however if one moves the VFO dial all the way to the right or left (and then beyond) the Silce receiver frequency will remain at the edge and the Spectrum with then move right or left. Those 2 icons are just used to center the Slice frequency and at the same time reduce or enlarge the audio passband on the spectrum scope. I would like the Slice frequency to stay fixed in the center of the Spectrum Scope/Waterfall.
73 John N2KBE0 -
Probably not what you are looking for, but, you can place the Slice receiver in the middle of the display and left click ( and hold) and drag the spectrum display back and forth and leave the Slice receiver in the middle.
I personally like to be able to place the RX frequency anywhere I want it.
I find it especially useful working CW DX. For example, I place the RX frequency to the left and expand the spectrum so I'm seeing say 10kHz to the right. I can then see all the stations calling the DX.
As usual, just my 2¢.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 60 Aurora
- 298 FLEX-8000 Signature Series
- 974 Maestro
- 948 Genius Products
- 348 Tuner Genius XL
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
