Flex 6600 and JRC JRL2K poweamp
Hi, just got my first Flex, a 6600 and I try to connect my PA JRC JRL2K solid state. But no luck. Is there anyone out there who have tride this setup?
Regards LA9VBA Ole
  • Ha Gei
    Ha Gei Member ✭✭✭
    Answer ✓
    There is a RCA connector at the rear for a relay output. You MUST define in the band settings which connector acts as a PTT forwarding for Linear AMP.
    I have no knowledge about a tuner connection, if the AMP has one at all.
    Harry
