Windows 11 and DAX Drivers!
Is FlexRadio going to address this problem. Windows Security blocks the install of DAX drivers. Ive tried the "fixes" that have been suggested and it doesnt work. Turning off the associated file in Windows Security only turns back on after reboot. Rite now my Flex 6400 is useless to me.
Allen WB7SWW
Allen WB7SWW
It will install and work ALLEN there is a couple things that need turned off in windows security on win 11. I can give you a list if you need. I would start with a fresh boot. and remove 4.1.15 completely including dax and we can turn off the necessary stooof… and reinstall after a reboot, it should work. I run a 6500 Erika K0DD
