Windows 11 and DAX Drivers!
Allen80
Allen80 Member ✭
Is FlexRadio going to address this problem. Windows Security blocks the install of DAX drivers. Ive tried the "fixes" that have been suggested and it doesnt work. Turning off the associated file in Windows Security only turns back on after reboot. Rite now my Flex 6400 is useless to me.
Allen WB7SWW
  • Erika - KØDD
    Erika - KØDD Member ✭✭✭
    It will install and work ALLEN there is a couple things that need turned off in windows security on win 11. I can give you a list if you need. I would start with a fresh boot. and remove 4.1.15 completely including dax and we can turn off the necessary stooof… and reinstall after a reboot, it should work. I run a 6500 Erika K0DD
  • Dave_WB1S
    Dave_WB1S Member ✭✭
    I am running Windows 11pro and SmartSDR v4.2.20 on my 8600 with DAX v2 Drivers. I have nothing turned off, Core Isolation, Memory Integrity and Kernel-Mode Hardware-enforced Stack protection ON. Intel Gen 12 core processor. MAP, LSAP and Secure Boot all ON, No issues what so ever.
    Dave
    WB1S
