Does FlexControl USB Control Have PTT Capability?
I have a AU-510 on order and plan to use the Windows SmartSDR program for operation. I have a wifi wireless headset for transmit & receive audio. I was thinking about adding the FlexControl USB Controlled Tuning Knob unit for easy tuning when in portable use. Just wondering if any of the buttons on the FlexControl can be programmed for PTT operation. I watched a couple of videos on the device where they programmed the buttons for several different purposes, but never saw the PTT programmed on the buttons. Is PTT one of the button choices to choose from? If that's not one of the choices I'll have to pursue other avenues for that.
Best Answers
  • Mick  W8BE
    Mick W8BE Member ✭✭✭
    Answer ✓
    Bill,
    I should have looked at the manual. This sounds like what Jeff was looking for in the 1st place.
  • Mick  W8BE
    Answer ✓
    seleting MOX will enable the Mox when you push the Flex knob.
  • Jeff Schmeichel
    Jeff Schmeichel Member
    edited February 9
    This was on a site called DC3CB.com and for FTDXRC CAT control software, using a FlexControl unit to control the Yaesu HF (FTDX-5000, FT-2000, FT-950) radio for remote operation. So I have no idea if the actual FlexControl software for Flex Radios is the same button options or not. But this is what I found.
    The FlexControl knob is used to tune VFO A, VFO B and/or the Clarifier. The three push buttons (AUX1, AUX2, AUX3) and the knob itself have three different states (single click, double click, long click) that can be assigned to different radio actions:
    noneTune
    VFO A
    Tune VFO B
    Tune Step Up
    Tune Step Down
    Tuning Acceleration
    Swap VFOs
    Copy VFO A to B
    Toggle Split
    Toggle Sub RX On/Off
    Tune Clarifier
    Clear Clarifier
    Toggle TX
    Clarifier On/Off
    Toggle RX Clarifier On/Off
    Altogether, you have 15 options. Are these the same button options in the Flex Control software?
    So if I'm reading this correctly it would look like "Toggle TX" would be the same as a PTT button if programmed into one of the AUX buttons. Please verify if anyone knows this is the case and I'll order a FlexControl USB device. I'd probably use some of the others as well, but the main functions I'm looking for are Tuning (dial) and PTT.
  • Mr Radio
    Mr Radio Member ✭✭✭
    Pressing CR button could possibly toggle PTT. It works in PSDR
    Tom
  • null
    Hello Tom, looking at the pictures online I don't see a "CR" button. I see 3 AUX buttons and the main dial knob. It sounds like all of them have a press function as well according to what I've read. Is there another CR button on it that I'm not seeing on the pictures? Can one of the buttons be programmed for that function. I don't know what PSDR is that you mentioned. Please clarify if you have time.
  • Mick  W8BE
    You could also just build a foot switch to send MOX off and MOX On commands via SmartCAT.
    https://github.com/w8be/usb-ptt-arduino-nano-every
  • I'm not a foot switch fan, especially when you're sitting back in a lounge chair or something like that. A hand PTT button is not out of the question, but I guess that my reason for asking about the flexControl USB device sold by Flex Radio. Apparently either nobody has or uses one, or I would think someone would know if any of the buttons can be programmed for the PTT (MOX). I might buy it just for the dial feature, but at $200 it would be great if the PTT was available with it as well. VOX really won't work in most outdoor conditions due to ambient noise in the area.
  • Mick  W8BE
    Jeff,
    The Nano Every is easy to shoe horn into a small space. You could also load FRStack as it has support for a hot keys. You could also put it on a Stream Deck. Some of the guys at our club take the cheap way out and use the space bar as it will run the last command you clicked on. It becomes the toggle switch until you click on something else. It sounds like may a stream deck or hotkey may work for you.
  • I'm not at all familiar with Nano Every, FRstack, or Stream Deck, but I'll do some Google research and try to figure out what you're referring to. I may try to contact Flex Radio in some way to find out if the FlexControl USB in their accessories area is capable of the PTT function. I just assumed that there would be someone in the group here that would have a FlexControl hooked up and in use on their computer, but I may have assumed wrong. Thanks for the replies and I'll check out the things you mentioned.
  • Mr Radio
    Mr Radio Member ✭✭✭
    CR- a long key at the bottom of the keyboard.
  • Oh okay, "carriage return", haven't heard it called that since the 70's. I'm trying to get away from the keyboard which is why my original question was about the FlexControl USB remote controller unit. This unit is available under the Flex Radio accessories pages, top row on the 2nd page of the listings. However it must not be a very popular item because it seems nobody out here in the community has one. I'm just wondering if one of the buttons on that device has PTT capability. Thanks for the reply though.
  • Bill AB7AA
    Bill AB7AA Member ✭✭✭
    Hi Jeff,
    I have a FlexControl and have just verified for you that it indeed has a MOX setting. You can program one of the buttons to do the MOX function just remember that it is always hot so it can be inadvertently activated by incidental contact. You push it once to transmit which stays active until you push it again.
    Bill AB7AA
    If you search here in the community, there are many solutions for the PTT issue.
    Mark has a great one as well!
    There was an error displaying this embed.
  • Thanks Bill, that's exactly what I was looking for. I knew there had to be somebody out there with one that could answer. I'll order one right away, it will probably get here long before the radio.
    Thanks again... Jeff S.
  • Thanks Mick, that will work great.
    Jeff S.
  • Mick  W8BE
    I just tested it and it does not work like I had commented. I set each of the buttons to MOX and found that pressing the knob button did not do anything. I had to press the actual button to get MOX to work. It works but still not ideal in my opinion..
  • Hi Mick, so you're saying you setup one of the 3 AUX buttons for MOX and when you pressed it, it does nothing? I mean you have the Dial (for changing frequency I assume) and the 3 AUX buttons. If you assign and of the AUX buttons to MOX (PTT), does pressing it activate the transmit function?
  • Mick  W8BE
    You can set each of the 3 buttons to MOX. Then depressing the individual button will turn on MOX when depressed. Depressing it again will turn it off. I was hoping the Flex Knob button would turn actually turn MOX on/off.
  • Thanks Mick, I guess the dial would be nice, although they maybe think you might bump the frequency when pressing it. Any of the 3 AUX buttons will be fine and do what I want. I just wanted to make sure it would work before ordering one. Thanks to all!
