Tuning TGXL with Maestro Remotely
Sorry I can't find any recent answers to this question searching The Community, although I'm sure it must have been discussed. I would like to tune the TGXL remotely from my Maestro. Currently I must open my laptop and use AnyDesk to connect to the station computer then use the TGXL app to tune the antenna.
I don't like this. AnyDesk has annoying nag screens, but it works. I don't really want to figure out if I even have a public IP or set up DYNDNS and change around router ports to run the app remotely. BUT, if this is possible, wouldn't it be possible to run SmartSDR remotely without SmartLink if you have a public IP? That would make it worth it for sure.
Otherwise, is there any other way?? It seems to me I should be able to run the station with the Maestro alone and not have to boot up another computer to tune the tuner. Thank you and Happy New Year!
Paul
N0GN
Oh my gosh. So Sorry. Excuse me. I was using the Tune Button. The ATU button works! Kind of. Sometimes it says low RF power. Sometimes it doesn't tune. Sometimes it tunes a little bit. It works fine when I click Tune on the TGXL app on the remote computer through AnyDesk pretty much every time. I must be doing something wrong. Also, Tun SWR meter on Maestro doesn't work a lot of times.
tap MOX to key then tap MOX to unkey. Now tap the ATU button and it should tune fine.
Ha! Well that's an interesting technique. Doesn't seem to be working though. I've been reading since and betting all my problems in life are due to too low VDC TGXL PS. I have this on order:
Do you think that's an acceptable selection?
I have another active post about VFO issue. I noticed that when I spin the VFO on the Maestro this caused the remote Maestro to crash. I hear relays click in TGXL when I do this. I can hear this through AnyDesk. But the clicks do not always result in a crash. Could the VFO problem be related to TGXL?
Also, I'm seeing messages popping up on Maestro every few minutes saying something's reconnecting to the network. The Maestro is on a different ISP than the shack. However, the IP number displayed on the Maestro is the local LAN IP of the Antenna Genius on the shack network! WTH???
Also seeing random remote connection crashes. Could these be due to TGXL?
I had upgraded TGXL to 1.2.17 and understand people have similar problems with that. Do you think downgrading would fix this without changing out the power supply?
Thanks!
try the new power supply. 4O3A recommends minimum of 15 VDC.
Spinning the dial fast on the Maestro sends a LOT of TCP commands to the radio quickly. Each step of the encoder will send the new frequency (for that step) to the radio) quickly and the radio in turn sends it to the tuner. The clicking is the tuner switching tuning solutions as the tuner will use the closest saved tuning solution.
Try turning the Slide A knob at a normal pace instead of just spinning it fast.73 Dave wo2x
It was ALL TGXL firmware version 1.2.17. Downgraded to 1.2.11 and almost all my problems went away. Network is handling VFO spinning with no problem. HOWEVER, as in the original post, Maestro A ATU button no longer works. But it works on Maestro C.
Actually, had to go down to 1.1.20 now. Lot's of features lost. Here's the last I heard from the Helpdesk in early January. Anybody hear any more since the last post? Here's the last I heard from them. Pretty sure I shouldn't have to pay to have this addressed…
I am going to ask Dave De **** to look at this. He is our resident expert on TGXL interfacing with Flex Radios. He may need to schedule a Paid FlexAdvantage session to log in to your computer and look at things.
Paul, this issue is being looked at by both Flex and 4O3A engineering. This issue does not affect all users. I personally use an 8600 v4.1.5, TG 1.2.17, PG 3.8.9 and AG 4.1.16. I have not had issues.
My setup has all RF equipment in a server cabinet in my garage connects to a 24 port managed GB Ethernet switch. That connects to a 16 port managed GB switch in my shack at operating position. One port goes to my router.
unfortunately there are almost infinite network configurations and trying the get a configuration to be able to consistently replicate the problem while doing network traces is very difficult.
If you have specific steps to boot everything up and working then be able to “break” it, I’d be happy to pass along.
You can revert back to 1.2.11 but will lose integration to SmartSDR and Maestro. Don’t forget toCompletely power down and the n boot up equipment if changing firmware version. This ensures the session IDs from Genius Equipment to the radio are recreated.
73 Dave wo2x
You mean like the picture below?? No TGXL firmware 1.2's worked. Had to go down to 1.1.20. I got the switch you guys told me to get. I dialed everything down to 100MF. I have all Cat VIII. The specific move to "break it" is to upgrade the software… To summarize, with the upgrade, the specific issues are that TGXL crashes every 10 minutes in a contest, it doesn't hold it's tuning solutions, Maestro ATU button is erratic. It crashes when you use the VFO in a reasonable fashion. Frequent remote connection crashes. Probably other things I'm not remembering now. I feel like I've been kind of ghosted on this since it doesn't affect all users. Maybe only a few? As far as I know my Helpdesk ticket is still open and last I heard they "sent it to engineering". I'm kind of tired of waiting. Are you telling me I have to get an 8400? Or is it possible my TGXL is a lemon? The TG, PG, and AG are all relatively new.
Oh, and Interlock issues too.
what else do you have connected to the radio?
Software - logging? FRStack? Other?
Hardware / to troubleshoot start with radio, Maestro and TG to a switch. No Internet, no PC. Minimize any network traffic for testing.
What version Maestro? What model Flex? (I am assuming a 6000 series).
What is the voltage to TG. 4O3A recommends 15 VDC minimum. I have seen issues with less than 14.5.The Dream Station configuration pdf has very good step by step process for introducing each piece of equipment.
Last, have you tested into a dummy load to rule out RF getting into network?
The big change with 1.2.17 is introduction of metering and control of TG into SmartSDR and Maestro which means more IP traffic to & from the radio.
sorry for all the questions but trying to understand what is different on your particular installation.73
Thanks David.
Spent an intimate evening with my Dream Station and TGXL 1.2.17 on the LAN. Computer is late model Intel Nuc with N1MM+ software and SSDR, AG, TGXL, DAX, CAT, and PGXL applications. No FRStack. I have to have the computer on, in order to tune the TGXL. I have to have the router on for DHCP to work.
Hardware is Maestro A. Flex 6700. TGXL. PGXL. AG. TGXL. PS is now 18V, 2A as recommended to me by Mike.
Issues occur frequently when no RF applied.Issues tonight are that just about every minute I hear a click, I think from TGXL, and a message comes up on Maestro that either IP x.x.x.149 (AG), or .150 (TGXL) has connected to the Maestro.
Frequently when I select a new band on Maestro, I get a message that the radio has disconnected. Then Maestro freezes. Then after a minute or so it reconnects. But CAT and DAX remain disconnected and I have to reconnect them by hand. Sometimes multiple times.
ATU button on Maestro is not working at all. Tun SWR and Tun Po meters aren't working.
have you done a factory reset of radio since upgrade to v4? Try that without importing profiles and test.
If OK then import profiles from v3 but uncheck Preferences. This will create a new persistence database.
73 Dave wo2x
Did that two weeks ago. Didn't reimport anything except repeater settings. Reset everything else by hand. Keep em coming. I'm at the site over the weekend and will try anything possible during the RTTY contest
If I can't get this worked out this weekend I think the TGXL should be replaced under warranty. I have done everything everybody has suggested for months now.
Also, if I go to the extreme and do another 6700 factory reset, is there some sort of factory resets I should also be doing on PGXL, TGXL, and AG? Does 6700 reset commonly fix this sort of problem, or is it basically a Hail Mary?
Paul
This issue has been escalated with both Flex and 4O3A engineers.
A workaround until the solution is introduced is to downgrade to TG 1.2.11 then reset all tuning memories (press and hold TUNE button on TG.)Once memories are cleared, go through each band and train the tuner. This requires dividing the 20 memories equally across the band. If you have antennas that are resonant at certain parts of the band, you can specify start and end of bypass segment in kHz, so 14.200 MHz is entered as 14200.000
This integration issue does not affect everyone and with so many different network configurations, trying to get a way to have it work, then break it on demand.
Training the tuner vs always initiating a tune when you QSY is the recommended operation. Again there are only twenty memories per band (and up to 4 antennas per band if you have an AG.73 Dave wo2x
Ok. That's a new one. I'll get right on it. Thanks!
I believe it in the quick start guide on 4O3A site.
I’ve posted examples on here on how I determine the start frequency to tune, and step size.
on 80 meters (500 kHz BW) I start at 3.510 and tune (after clearing memories). Then move up 25 kHz (bandwidth of band divided by 20 memories, 500 kHz/20=25 kHz step. Tune at 3.535 3.520 + 25 kHz). Move up 25 and tune. Repeat until 20th memory is at 3.985 MHz. Now you will never be more than 12.5 kHz from a valid tuning solution.
Smaller bands like WARC bands only need 2 or three memories.
73 Dave wo2x0 -
Ok. That helps. So the principal is to just make sure it never autotunes? And it's ok to use less than 20 memories?
I'm not really seeing what you're talking about on the 4O3A website except the 75 page user manual that doesn't say anything about this. In fact, I can't even find the thing about 20 memories. I must be looking in the wrong place. If you have a copy, could you attach it?
yes. And it will not autotune. You would always need to tune if SWR is high. It is not automatic.
I gave you formula for step size. To calculate start frequency take band’s bottom edge (3.500 MHz) and add 1/2 a step size so 3.500 + (25kHz/2) = 3.5125 MHz. I rounded down to 3.510 MHz to make it easy.73 Dave wo2x
Since downgrading and setting all the tuning memories on every band, the Dream Station has become a lot more tame. I was able to run in the contest with almost no problems over SmartLink. Except my 80m antenna has a fairly narrow bandwidth and would require a lot more than 20 memories. That limitation is disappointing.
Also, I have noticed on CW and now RTTY that even on the LAN, the sidetone audio is really broken up. They seem to understand what I'm sending but it sounds awful on this side. Sample attached. Is this a known problem?
Are you saying after training the tuner, go to one of the tuned frequencies then move 12 kHz up or down that your SWR changes that much? My 40/80 antenna is a compromise on 80 and does not natively have any resonance. I do not have a problem keeping SWR under 1.6:1 (usually lower)
moving 13 kHz up or down from a tuned frequency should cause the relays to change as the TG will now use the closest tuning solution and not the original.
73 Dave wo2x0 -
That's what's happening now. It's a new antenna with very narrow bandwidth, but I didn't think it was THAT narrow. I think it might be a bad polyphaser. Thanks for the explanation on how it actually works. I just noticed you posted about this a few weeks ago.
Still going strong working WPX RTTY remote this morning. It's workable, but I'll be very happy once I can use the ATU button and get TGXL meters working on my Maestro.
Any comment on my Xmit audio issue? Every time I ask if something's a known problem, I never get an answer from anyone. Is this a policy determined by lawyers or something? Once I was told there was a known solution for my crashing problem by just downgrading AND setting the tuning memories, all was well. I may have missed that somewhere in my extensive inquiries but I really don't recall that being said before. Or maybe it was a recent discovery. In the meantime, though, I have been jumping through very time consuming hoops for months
Another contest weekend nearly in the books. Only a few crashes on the first night. As you suggested I'm trying to pin down specific events to help you troubleshoot. The first time, an hour into the contest, Maestro was on the local radio LAN. I entered 28001 in N1MM+ entry window to QSY. Immediately got the message on transmit "Interlock is preventing transmission AMP:AG". I switched to SmartLink but a similar thing happened shortly after. It kept happening every 1-2 hrs I'd say throughout the weekend. It seemed pretty random most of the time and usually independent of band changes. It did seem to happen more often when I was running. Sometimes, I'd let it rest a few seconds and it would work again. Other times, I'd have to cycle TGXL. Once, I had to recycle it and PGXL. Lost a few multipliers which is frustrating, but for someone contesting with a Dream Station at a sub-elite level, it's useable. Has there been any progress on a fix? I read that switching to analog PTT has helped some contest stations. Do you have a recommended way of doing that on a remotely operated station?
- 650 The Flea Market
- 153 SmartSDR+
- 49 Aurora
- 964 Maestro
- 937 Genius Products
- 343 Tuner Genius XL
