SmartCAT not creating ports
Something wonky happened and SmartCAT is not seeing all the Flex COM ports in device manager. They are all there and active (not grayed out). But they don't show in SmartCat.
When I try to create a new port in SC I get an error saying to check the settings but they are all correct. Not using a port showing in device manager and no hidden ports.
Should I reinstall SSDR 4.1.5?
Delete current one first?
Greg
Remember com port 1 also has a matching com port 101... com port 10 has a matching com port of 110... make sure you see both. If you allow the system to create automatically it makes both. If you get into advanced mode you risk selecting mismatched pairs and nothing works. These things are like virtual ports theres two ends. In and out. Erika K0DD
Thanks but not the problem. Appreciate the insight though!
Resolved. Uninstalled everything again but this time I also deleted all the appdata files. Working well again!! It was the appdata files that got corrupted. Dudley also showed me that when you Right click on REMOVE in SmartCAT there is a reset option. Did not know that.
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
