Zerotier Layer 2 Bridge for Flex Radio Remote Operation
Mike-VA3MW
Danny, k5cg, did this cookbook on how to use ZeroTier for remote Operation and he asked me to share it.
If you want, give this a try and feel free to post your questions if you get stuck.
  • K5CG
    K5CG Member ✭✭
    Thanks for posting this Mike.
    As noted in the document, if you create a new account at zerotier.com and use the New Central Web UI, please send me the screen shots of the pertinent settings section if they are substantially different than what is in the document. I would like to have the images for both Web UIs.
    Danny
  • K5CG
    K5CG Member ✭✭
    edited November 2025
    I made some edits and created distinct documents for Zerotier's Legacy Central and New Central Web UIs. Here are links to documents on how to do either.
    Legacy Central Web UI (Existing accounts)
    New Central Web UI (New accounts)
    Let me know if you see any issues or needed corrections.
  • K5CG
    K5CG Member ✭✭
    These guides were updated today to include potential missed steps regarding installation of additional system services.
    I also created a new document specifically for Raspberry Pi (3/4), tested and working.
    Let me know if you see any issues.
  • F4BPO
    F4BPO Member ✭✭
    Hi Danny,
    Thanks for the tutorial anyway I am facing an issue.
    After I add the 4 files and reboot I cannot connect to my Debian box through ssh and I never achieve from outside the network to actually connect to my LAN, not sure what is wrong I have followed three or 4 times the manual you made both with legacy and new Central Web UI but none works.
    If you or someone have to time I can send the screenshot of current config to compare with yours ?
  • K5CG
    K5CG Member ✭✭
    @F4BPO I sent you a direct message on how to contact me via email.
  • F4BPO
    F4BPO Member ✭✭
    received thanks and problem solved even if I have other issues now
