CW Autotuner Intermittent?
John K3MA
John K3MA Member ✭✭✭
Before submitting a ticket, I was wondering if anyone else has experienced CW Autotune not working on a slice. Either one shot or intermittent.
Most of the time it does not work on the A slice and if I create a B slice it will work on the B slice.
  • Dan Trainor
    Dan Trainor Member ✭✭✭
    It's in an experimental state at this time. You can expect it to stabilize in future releases.
  • John K3MA
    Dan, thanks for the insight. I do not recollect seeing any communication from Flex that the CW autotume is experimental. I must have missed it somehow. Would you please point me to the link for this information?
  • Gord-VA7GP
    Gord-VA7GP Member ✭✭✭
    edited January 23
    For me, I find the CW Autotune depends on signal strength. If the signal is weak, Autotune doesn't work. If the signal is medium, or strong, CW Autotune works nicely.
    So, a 449 signal with QSB is going to require that I use my ears. A solid 569 or better Autotunes well. I've only tried the One Shot mode.
