SmartSDR & WJST-X Developer Edition
With the Flex connected via TCP, these RIG DATA fields are unavailable.
Is there a way to enable this to stop TX when SWR is high?
Is there a setting in SmartSDR to stop TX when SWR is high OR enable auto-tune to tune it out?
Revisiting this question.
No answers from Flex ? Perhaps something to add the features list ?
Andy K3UK
The data is available on the radio if the developers know how to pull it. Please check with them and if it doesn't work, there is a path for the developers to reach out. I suspect this is a Hamlib issue maybe?
(It does work, because I use it within NodeRed).
Mike, WSJT-X uses CAT to get the data from the radio. In our case it is SmartCAT. I debugged the CAT interface and found that there is no CAT command to get the SWR from the radio (according to the SmartCAT reference manual). I don't see how this feature can work unless :
- Flex creates a CAT command to fetch the SWR data
- WSJT-X starts using the TCP/IP interface and subscribes to SWR meter data.
Regards
Correct, there is no CAT command to get this data.
In order to get the data, it has to do a TCP connection and subscribe to the meter data and not use a tradition CAT connection.
Maybe the developers will move in that direction as there is so much more data available.
- 652 The Flea Market
- 384 SmartSDR API
- 50 Aurora
- 967 Maestro
- 938 Genius Products
