WSJTX POWER AND SWR
How do I get wsjtx power and swr feature to work with my 6600m ?
  • FRED  W9TB
    FRED W9TB Member ✭✭
    I don't think that WSJT does power and swr, but maybe I am missing something?
  • Mick  W8BE
    Mick W8BE Member ✭✭
    It does. However I only got the power level to show up. It appears on the power slider on the right side of the main panel.
    what version of WSJT is that?
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    wsjt-x_improved
    It sounds like you need to reach out to the author and see what radios it is supported with. Those value are available from a FlexRadio on a TCP/IP connection but the application software needs to support it.
  • Mick  W8BE
    Mick W8BE Member ✭✭
    edited January 20
    Here is the version number…
    Here is the info in the release notes…
    Transmitted Power and SWR can be displayed (as reported by the   radio) in a Status Bar label. Transmission can be stopped   automatically if SWR exceeds 2.5.  These features work with most   modern radios controlled via Hamlib or FLRig.
    If that was to work, and I can't see if Hamlib actually supports it with FlexRadio at the moment, you would need to be connected to the radio via TCP/IP. If you aren't doing that already, you might want to give it a try.
  • Geoff AB6BT
    I can see the Power data but cannot see any SWR data
