WSJTX POWER AND SWR
How do I get wsjtx power and swr feature to work with my 6600m ?
I don't think that WSJT does power and swr, but maybe I am missing something?
It does. However I only got the power level to show up. It appears on the power slider on the right side of the main panel.
what version of WSJT is that?
wsjt-x_improved0
It sounds like you need to reach out to the author and see what radios it is supported with. Those value are available from a FlexRadio on a TCP/IP connection but the application software needs to support it.
Here is the version number…
Here is the info in the release notes…
Transmitted Power and SWR can be displayed (as reported by the radio) in a Status Bar label. Transmission can be stopped automatically if SWR exceeds 2.5. These features work with most modern radios controlled via Hamlib or FLRig.
If that was to work, and I can't see if Hamlib actually supports it with FlexRadio at the moment, you would need to be connected to the radio via TCP/IP. If you aren't doing that already, you might want to give it a try.
I can see the Power data but cannot see any SWR data
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 269 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
