6500 when turned on goes into scan mode
6500 when turned on goes into scan mode recently put new sd card worked for a while now don't know what to do maybe do reboot help please help
    Hi Richard, SmartSDR doesn't do scanning, so I am not sure what you mean. Can you describe the symptoms?
  • richard sabo
    richard sabo Member
    I start up 14.200 and it start scanning to end of band
    That is not normal… Do you have any other applications running? Do you have a FlexControl, Maestro or anything like that?
    If it is not some other application or device, then I would export profiles and do a factory reset.
    Are you using FRStack?
