6500 when turned on goes into scan mode
richard sabo
Member ✭
6500 when turned on goes into scan mode recently put new sd card worked for a while now don't know what to do maybe do reboot help please help
Hi Richard, SmartSDR doesn't do scanning, so I am not sure what you mean. Can you describe the symptoms?
I start up 14.200 and it start scanning to end of band0
That is not normal… Do you have any other applications running? Do you have a FlexControl, Maestro or anything like that?
If it is not some other application or device, then I would export profiles and do a factory reset.
Are you using FRStack?
Do you have anything plugged into the microphone? I ask because the Up/Down functionality may be getting triggered and causing the frequency to walk up the band.
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
