Flex6400 with direct internet connection looses after several hours connection.
Hi all,
Have a FLEX6400 (4.1.5.39794) which is wired directly to a 1GB switch with the PC and then off to the router.
The issue is the radio internet status goes to NONE after X hours of use/none use.
My setup is using either DHCP or manually assigned IP address.
SmartSDR and all the other programs connect perfectly.
Network switch is unmanaged with no smart features/firewalls etc.
From the router you can ping the FLEX:
Reply from 192.168.0.40: bytes=64 ttl=64 seq=4 time=0.678 ms
UPnP shows:
FlexRadio SmartLink TLS Port 192.168.0.40 4994 21000 TCP
FlexRadio SmartLink UDP Port 192.168.0.40 4993 22000 UDP
When rebooted you have internet - and Smartlink shows as a green pass.
Leave it connected and powered on overnight and you come back to NONE and no Smartlink.
A reboot always restores the internet connection to the radio.
I *do* want to use it remotely when out of the office, sadly, I cannot at this time without someone rebooting the radio.
73 Steve
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    Just for fun, try bypassing the switch (and the router) with a cable direct to the radio. Let us know what happens. It's probably something in the network. For whatever reason, many GB switches are problematic.
