How can I view the entire radio setup window?
chuckad4es5395
Member ✭
in SmartSDR+
When I click on Settings then radio setup and view the radio tab the information regarding smart SDR+ and smart SDR++ is cut off as if the window is not large enough. I can see at the bottom "License Info" and Subscription NONE Expiration None but nothing below that. Please note that I have ordered the SDR+ even though it says NONE.
What can I do to see the entire window?
Hi,
It would be helpful to have a screenshot of the window
and which version of Windows you are using.0 -
Klaus,
I have a screen shot but I do not understand how I can post that. Please help!!
I am using Windows 11 and Flex 4.1.5:0 -
Hi Chuck… create a message here and in the body 'paste' your screenshot. If it doesn't work, it may be because the forum software wants you to make a couple (or so) 'regular' messages before it allows adding pictures.
Hi Chuck,
if you see this here:Click on the picture icon and your file manager will open.
Select your screenshot and you're ready to go.
If your system does not provide this function, simply send me the image to om@df3rp.de and
I will post it here.
73 Klaus0
- 681 The Flea Market
- 219 DAX
- 394 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
