How to connect LOG4OM to remote 8400 using SmartSDR/CAT using hamlib
So, if anybody know how to connect hambli to a remote 8400 via SmartCAT, I'd be very grateful for a hint or config for SmartCAT or LOG4OM.
Thanks Steve - VK3SPX
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Steve
If you works locally, the setup is identical for remote. You start CAT on the same computer as LOG4OM and let CAT do the SmartLink connection to the radio.
Now that you have that CAT port, you tell LOG4OM. You can also just tell LOG4OM it is a Kenwood TS2000 radio and it should work just fine.
I do not use LOG4OM, but that is where I would start. Others may be able to help.
HI Steve… I don't operate my 6700 remotely, but I use SliceMaster to connect Log4OM to the 6700 via the 'hamlib' TCP cx on Log4OM. If you want more info, just let me know and I'll be happy to post screenshots, etc.
Thanks Mike and Don,
Mike, the method you describe is more or less what I have tried with no success.
Don, I'll have a look at Slicemaster, although why it should be required I'm not sure.
I have however found another method that seems to work.
My SmartCAT 4.1.5 (running locally on my computer which is remote from the Flex) exposes two cat port. Firstly a Serial COM port (COM7 for me), Slice A "Auto Switch TX" and secondly TCP Port 5002, Slice A "Auto Switch TX" .
As I mentioned in the previous post, Omni-Rig is happy to connect to the virtual com port, but hamlib is not.
Ie the command "rigctl -m 2036 -r COM7 f" which should fetch the VFO frequency of the Flex does not work, however "rigctl -m -r 127.0.0.1:5002 f" does work.
There appears to be something defective or weird with the virtual comports that SmartCAT creates.
Anyway, I guess I have a way forward.
If anyone has an idea why the virtual com port does not work as expected I'd love to know. Perhaps Slicemaster will do a better job, although I'm not sure that is intended for the remote computer.
Steve
VK3SPX0 -
Steve… SliceMaster is not required, but it does make things easier :-) It helps with setting up the TCP ports correctly and connecting up to the various other software and the Flex. I use Slicemaster to allow me to use TCP port, rather than COM ports.
Thanks Don. I might give it a go anyway. TCP created by SmartCAT seems flaky.0
- 685 The Flea Market
- 195 SmartSDR+
- 102 Aurora
- 994 Maestro
- 971 Genius Products
- 357 Tuner Genius XL
- 133 Antenna Genius
