Use of +ACC
The user guide states:
ACC button: Clicking this button will enable audio input and output on the ACC connector on
the rear of the FLEX-6000 at the same time as a different primary audio source.
Does anyone use this function and if so how?
Thanks.
  • KlausP
    KlausP Member ✭✭
    Hi,
    I have connected my Rode microphone via the UR6QW equalizer to this connector on my 8600 and it works well.
    Since this is a line-in connector, I assume that a normal microphone signal will not be sufficient.
    My connection ACC-adapter:
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    Thanks for the info. I've had two responses so far. The other was using the connector for a PACTOR modem.
  • KlausP
    KlausP Member ✭✭
    Now, PACTOR is not my area of expertise.
    But as far as I know about these modems, their audio signals operate in the range of 10 mV - 2 V p-p,
    which corresponds to the Line I/O specification.
    Therefore, I think this port is exactly the right one.
    Klaus DF3RP
