Use of +ACC
The user guide states:
ACC button: Clicking this button will enable audio input and output on the ACC connector on
the rear of the FLEX-6000 at the same time as a different primary audio source.
Does anyone use this function and if so how?
Thanks.
Hi,
I have connected my Rode microphone via the UR6QW equalizer to this connector on my 8600 and it works well.Since this is a line-in connector, I assume that a normal microphone signal will not be sufficient.
My connection ACC-adapter:
Thanks for the info. I've had two responses so far. The other was using the connector for a PACTOR modem.
Now, PACTOR is not my area of expertise.
But as far as I know about these modems, their audio signals operate in the range of 10 mV - 2 V p-p,
which corresponds to the Line I/O specification.Therefore, I think this port is exactly the right one.
Klaus DF3RP0
- 388 Community Topics
- 156 SmartSDR+
- 53 Aurora
- 970 Maestro
- 944 Genius Products
