Support to tx proper cat signal to get the acom 04at tuner to tune when request cat comes to tx cat
mnewbill
mnewbill Member ✭✭
I "think" all we need here is ability for the cat requested tx from set 5 to be "fm" or even better to activate the tune button instead of RTTY or SSB from DAX audio, which when the amp requests a tune, will be silent and not make an output. (selectable somewhere so the digital mode folks can also still use the cat request to tx.)
can this cat tx request be a selectable item in a menu somewhere what mode is triggered when incoming cat tx request for tune comes on kenwood set 5 type command set?
thanks,
MN
2 votes
Active · Last Updated
  • mnewbill
    mnewbill Member ✭✭
    update
    i found i can tune ok by pressing tune on the amplifier acom 1200s with 04at on it and then immediately press tune on smartsdr. this works ok most of the time. there is still some glitch where when tuning completes smart sdr resets to a frequency of zero. i have to then go back to the band i just tuned on. i think this is the larger problem.
  • mnewbill
    mnewbill Member ✭✭
    i beleve what happens is after the acom completed the tune it sends cat data back to smartsdr to turn off the transmitter and restore power level back to the previous level and somehow its misinterpreted as select band or frequency of zero or lowest possible frequency.
  • mnewbill
    mnewbill Member ✭✭
    wish i could upload a video, I captured the event. thanks, MN
    Upload it to YouTube and then provide the link.
  • mnewbill
    mnewbill Member ✭✭
    I know in the video, I left out the comment, that why I press "tune" on smart sdr is to give it a carrier, as the requested tx by the cat cable apparently is afsk, which with no input tone is no carrier. so the amp is moving the power level up and down via cat, and then when I press smartsdr tune button, it will then quicly tune, and turn off the tx.
    sometimes it works ok, most of the time, it goes off frequency when it completes. if I lock the slice, it works ok other than having to manually press smartsdr tune, and manually raise the tune power.
    this can be closer to normal if you set up a dax channel and 2khz sine generator, but starting all of that up just to tune, is harder than manually pressing the tune and moving power, so not really a great work around there in my opinion, but it simulates a better working condition.
