How to receover from SmartSDR 4.x not running on 6600?
I have been trying to get assistance from Flex's Helpdesk but they are not respomding, so I though I would try here to get some answers from my fellow users. Any help you can provide will be appreciated.
Here is the text of the second message I sent to Flex Helpdesk with no response for more than 10 days.
It has been suggested in this forum that a factory reset and then a manual rebuild of all profiles *may* or may not fix the problem. This radio was purchased in 2019 and has had many successful updates from Flex, but I can't really do that, given the radio's current state.
I miss using my Flex 6600 and would like to have a working radio. Any help would be appreciated..
This is a follow-up to your previous request #76911 "Smart SDR 4.0.1 keeps disconnecting from Radio after upgrade"
I did not get an email advising this ticket was updated or closed, so I have simply stopped using my Flex doorstop.
It will be very difficult for me to find all of the updates I have made to the stick profiles from memory. Because the radio/SSDR crashes so often, it might take hours of reboots to extract all of my customizations. So, it seems simplest to downgrade to a working 3.x release and then identify all of my changes on a working radio.
What release should I downgrade to? Is a downgrade as simple as:
1) start the desired SSDR release on Windows.
2) Downgrade the Firmware
3) power off radio, remove 12VDC for 2 minutes.
4) Power on radio, holding power on button untl it turns purple to factory reset radio.
5) reload working profile from 3.10.
6) Power off/on radio, then start SSDR 3.x and start using the radio..
I really wish v4.x would work for me, but it looks unlikely at this point. I paid $150 for access to update 4.x features, but I don't suppose I will be able to use them any time soon.
One final question: Will V4.x work on Win7? I understand that it may not be recommended, but I am asking if there are any known issues with V4.x on Win7?
Dale
    This is very likely the solution to your problem and about 99% likely it will resolve your issue.
  • edtyler
    edtyler Member ✭✭
    Thanks for your reply. Does this mean that the procedure I outlined is correct?
    Also, any comments on running SmarSDR 4.x on Windows 7 would be appreciated.
  • Erika - KØDD
    Erika - KØDD Member ✭✭✭
    I would copy off your existing profiles to another storage device like a quality sandisk unit. Then delete them out of the directory.
    I would do an uninstall of all of your versions of ssdr. Including the dax and cat drivers. If anything is left in those directories delete those. Restart your computer. Factory reset the 6600. Cold boot. Then Download a fresh version of 4.1.5 install and update the radio. Cold boot radio. Restart computer. Then manually rebuild a basic profile. Use radio and see how it works. Dont even have old profiles or versions. You'll need to refresh if you have subscriptioned v4. Youll have a basic simple profile to start. Fresh everything. If it acts up. Your problem may be sd card. But my guess is your radio will be fine sometimes this upgrade just boogers up. Thats how i fixed mine. Erika K0DD reboots are your friend, clean slates are your friend
    Profiles are a pita. Why when testing keep things simple good luck
  • edtyler
    edtyler Member ✭✭
    Erika, Thanks for your reply. Profiles are a obviously a problem with X4.x. They worked fine in V3. Not having profiles means that I can't have specialized settings for different antennas, TX ports, microphones or RX/TX audio equalization. Also can't have any settings for transverters. Sounds like quite a limiting factor for V4.x
    How do you get around these limitations on V4.x?
    Also, do you run SmartSDR under Windows 7?
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Hi Ed… it's not that you can't have Profiles in v4.x, it's just that a number of us have found that trying to import v3.x profiles into v4 can sometimes cause problems.
    A number of us have found the best solution is to simply NOT import the 'old' profiles into v4 and simply recreate them from scratch. A pain, I know, but it does seem to settle things down remarkably.
    As Don says, profiles work fine on V4, but if you happen to have a corrupted profile in v3, and you may not know, it can migrate into v4 and cause some weirdness.
  • edtyler
    edtyler Member ✭✭
    Thanks for the replies.
    I feel like I can get back to a working radio using the procedure I posted and then assess V4.x again in the future. I have to see if Flex will refund my SmartSDR+ subscription, since V4.x has not worked for me so far.
    Still wondering about running V4.x under Windows 7. Going to Win11 seems like a big backwards step, with the spyware and ads on the desktop.
    Anyone running SmartSDR V4.x on Win7?
    Thanks, and 73,
  • Erika - KØDD
    Ed this just popped up again in my mail messages. I didnt say you cannot use profiles. I said delete everything on your computer in the ssdr directories and all of the old profiles. Then instal 4.1.5 back on your computer, and back on your radio from cold boot. Then create a simple profile to run your radio and make sure it does real radio stuff. V4 is so much more advanced than v3. Its a big step up. But i did each update when they came out and somewhere in the process things got goofed up. The radio acted really badly. Just dont cut corners **** off all the old files profiles everything something happened and nobody knows where the damage is. Then do a completely fresh clean install... from scratch with zero chance a broken file can hurt you. Just like mike said 99 percent chance my total cleaning process will fix your problem... but if your going to scrap the radio send it to me. As i can always use another one and know this is an easy fix. Then write down everything in your profiles so a rebuild is easy...
    Windows 7 i had a few hundred windows 7 computers once. Worked good. Last one i had was in 2006 or7... have a nice weekend
  • David Decoons, wo2x
    What works for some is to import the v3 profiles with Preferences unchecked.
    73 Dave wo2x
  • edtyler
    edtyler Member ✭✭
    Following up with the resolution of this issue.
    1) reverted to 3.9.16
    2) poweroff 12VDC for 2 minute
    3) factory reset
    4) reloaded a working profile. The radio worked properly, as expected. Captured screenshots of configs.
    5) upgraded to 4.1.5, which failed to complete.
    6) shutdown, then powered off 12VDC for 3 minutes
    7) powered on, did a factory reset on 3.9.16, which was still installed, then powered off 12VDC for 2 minutes
    8) restarted win7
    9) powered on radio, did factory reset again
    10) upgraded to 4.1.5, which completed
    11) shutdown radio, powered off 12 VDC for 2 minutes
    12) powered on radio, did factory reset
    13) tried to start SmatSDR, it hung for a while, then failed to start CAT/DAX
    14) shutdown, hen powered off 12 VDC for 2 minutes
    15) restarted win7
    16) powered on radio, did factory reset
    17) started SmartSDR, this time it came up, but with incorrect network addresses.
    18) Fixed network addresses, which restarted radio.
    19) Closed and restarted SmartSDR
    20) Things seemed to be stable with no crashes for about an hour
    21) restored configs manually from 3.9.16.
    22) testing now. No crashes but some improper operation - no 60M transmit, etc.
    Conclusion - Flex did a poor job of testing migration scenarios and obviously has failed to learn a basic lesson of software development - Check all of your inputs (configs, etc) and provide clear indications of what's wrong. Do not just crash randomly, or if you must crash, provide a clear indication of what went wrong. I am very disappointed in Flex's responses to the problems they caused for the user community. Flex's reputation for quality has taken a big hit in my view. I hope they can recover from this by improving their processes.
    I am not sure I will be able to continue to use 4.1.5 without full functionality, but I'll submit cases to try and resolve these defects.
  • ka9ees
    ka9ees Member ✭✭✭
    I didn't think v4.1.5 would run properly on Win7.
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    Yes, Flex testing makes all of us into Beta testers.
