Maestro C crashes when spinning VFO
Paul Christy
Paul Christy Member ✭✭
I have a peculiar issue. Every once in awhile when I give the Maestro VFO A knob a good spin, the Maestro just crashes. Sometimes it just disconnects from the network and reconnects by itself. Other times I have to actually reboot the Maestro with the power button. Has anyone else seen this behavior?
    Which version of Maestro and what version of SSDR?
    When you do that, you are sending a TON of commands to the radio in a hurry as that is not really what it was designed for. It is possible the NIC card in the Maestro can't keep up.
  • Paul Christy
    Ok. Well that makes sense. It's kind of like the behavior I see due to my presumed network problems we're talking about in the other threads. But sounds like this is completely unrelated. I'll try to throttle down my VFO spinning :)… Thanks!
