crashes with 4.1.5
I seem to be getting more than a few crashes showing dot net exceptions with this version. Just sitting there monitoring digital stuff with wsjt and jtalert running. It might run for 6 hours and then suddenly dump. Anyone else seeing stuff like this? I wasn't having any issues with 3.10 or whatever I had before 4.x
  • aa1ffradio
    aa1ffradio Member ✭✭
    None here . . . Mine will run for days with no crashes. Turned the radio off twice in the last month of ownership
    No problem with my 6400 or 8600 both running 4.1.5. You might want to try a factory reset if you haven't already. Be sure to export your profiles first.
  • ka1jy
    ka1jy Member ✭✭
    I have done the factory reset. This radio crashes 3 times a week. This morning it dropped off the network. Didn't even answer pings. I used a fixed IP address so it was off. No problem with the cables, unmanaged ethernet switch or anything else on the network. I think I got stuck with a used lemon.
    Hi
    Let's do some testing just to be sure it isn't the switch. Gigabit switches seem to be problematic, especially the lower quality versions. You may also want to try using just a 100mb switch and see if the problem goes away. Sadly, not all switches are equal. Some are just .. junk to be honest.
    We want to do this before sending something in for repair as this is the test they run when diagnosing a communications layer issue. It creates a very simple network.
    Diagnosing Network Issues with a Link-Local Test
    A Step-by-Step Guide for FlexRadio Users
    Introduction
    FlexRadio transceivers rely on stable network connections for optimal performance. If you’re experiencing disconnects, audio dropouts, or other network-related issues, performing a Link-Local Test helps determine whether the problem lies with your radio or your network.
    This test directly connects your PC to the radio, bypassing any external network components.
    This document outlines how to conduct the test and interpret the results.
    Why Perform a Link-Local Test?
    • Isolates the Problem – Helps determine if the issue is related to your network or the radio itself.
    • Eliminates Variables – By removing routers, switches, and other network devices, we can focus on potential hardware or software issues.
    • Simplifies Troubleshooting – If the radio works properly in this test, then the issue is within your network setup.
    Step-by-Step Instructions
    1. Gather Required Equipment
    • Your FlexRadio transceiver
    • A PC or laptop running the latest version of SmartSDR
    • A single NEW LAN (Ethernet) cable
    2. Power Down Your Equipment
    • Turn off both your PC and your FlexRadio completely.
    • Unplug any existing network connections to ensure no external devices are affecting the test.
    3. Directly Connect the Radio to the PC
    • Use an Ethernet cable to connect your PC directly to the LAN port on the FlexRadio.
    • Do not connect the radio or PC to any router, switch, or other network devices.
    4. Power Everything Back On
    • First, turn on your radio and allow it to fully boot.
    • Then, turn on your PC and let the operating system load completely.
    5. Launch SmartSDR
    • Open SmartSDR on your PC.
    • In the radio chooser window, check if your radio appears as an available device.
    Interpreting the Results
    ✅ If the radio appears and works correctly:
    Try to recreate the same problem.  If you are not able to, then this means your radio is functioning properly, and the issue likely stems from your network setup
    The next steps are:
    • Check for faulty Ethernet cables, switches, or routers.
    • Ensure your network is properly configured for SmartSDR.
    • Look for any network congestion or interference.
    ❌ If the radio does NOT appear or crashes:
    This could indicate a hardware or software issue with the radio or PC. In this case:
    • Restart the test to confirm consistent failure.
    • If the issue persists, contact FlexRadio Support and report your findings.
    Conclusion
    The Link-Local Test is a crucial step in troubleshooting network-related issues with your FlexRadio system. By eliminating network components, you can quickly determine whether the problem is internal to your radio or caused by your home network.
    If you require further assistance, please reach out to FlexRadio Support with your test results.
    🔗 Submit a Support Ticket: https://helpdesk.flexradio.com/hc/en-us/requests/new
  • ka1jy
    ka1jy Member ✭✭
    It is a netgear GS308 - I have 5 of them deployed in various locations including my remote site. I have definately seen some failures which is why the first thing I did was connect the radio with a new cable to a different switch. Since the problem takes days to happen is seems quite unlikely it is related to the switch or the network. My other Flex has been on for weeks without any issues. But I will do the test. In fact I can put this PC on both the ethernet and the local network but I may have to change the IP addresses to create an alternate subnet. (otherwise the PC won't know which network to talk on).
    I am a little confused even if my network did drop why the radio would do a power down reset. Seems like odd behavior
  • ka1jy
    ka1jy Member ✭✭
    I posted the crash dumps on the help desk. Plus a lot more information on the crashes. Millions of packets showing on the network status windows with 1 or 2 dropped packets. The application crash dumps show dot net exceptions on the crash event log. That doesnt really point to a network conductivity problem. Also the hard power down style resets for no reason seem strange. I changed power supplies and power after the first one but it happened again. I can pull the network cable out of my other 6600 and it stops but it doesn't crash the app or the radio. Also tested with multiple pcs. At any rate it is running now with a brand new cable direct. We will see but I'm not optimistic.
  • ka1jy
    ka1jy Member ✭✭
    it may run for 2 hours. Or a week. Just have to wait and
  • johnn1jm
    johnn1jm Member ✭✭✭
    I had a very similar problem like this with a 6600. I also had a 6400 on the same network that was solid. It turned out I sent the 6600 to Flex and they replaced the SD card and the FPGA board, fortunately under warranty..
    John N1JM
  • ka1jy
    ka1jy Member ✭✭
    Same deal. It ran for a whole day this time and then poof - out it goes. "SmartSDR (V 4.15.39794); An unhandled exception has occured: 'Sorting' is not allowed during an AddNew or Edititem transaction" followed but 50 lines of blah blah from various methods status etc. No clue why it did that. I wasn't even in the room. The radio was just sitting on 75meters LSB listening to static. I wasn't sorting or adding or editing or anything. The windows reports SmartSDR has lost connection to the radio. Then the thing appears to be running but when I click out of the error boxes SmartSDR goes off leaving Dax and Cat running without a connection. Only other interactive process running was my rotor control. Which is fine. Windows event long around the time it crashed is clean - only shows the dot Net fault. Similar to the screen dump. Followed immediately by an "application error". Excact same time stamp on both so I am not really sure of the order. No other windows events today, which is pretty good from what I have seen. Direct cabled to the PC this time. No other network. I was going to run the PC with both ethernet and wifi but I decided to just leave the wifi off. I don't know if the radio rebooted this time. I wasn't in the room.
  • Tim K9WX
    Tim K9WX Member ✭✭✭
    I had been using 2.12.1 with my 6600 for years and decided to upgrade to 4.1.5 last week. The new noise mitigation features were very impressive. But I ultimately downgraded to 3.10.15 due to the instability I found in 4.1.5 and by that I mean crashing the radio. One example: I operated a bit with N1MM and used the N1MM Alt+F6 keyboard shortcut to swap VFOs while operating SO2R. I did it three times and each time it crashed the radio. I will wait another 1 or 2 versions of 4 before I try again. Meanwhile, 3.10.15 seems very stable. Which it should be as it was the last release of V3 before V4 debuted.
    Tim K9WX
