3K from band end - transmission interlock
At 14.347.0 transmission interlock appears. If I go to 14.346.9, no transmission interlock. Same occurs on 15m band end. Haven't tried other bands. I use to be able to transmit 3K from the band end. Do I have some setting that is incorrectly set?
    Hi Dom, if you cut your TX Filter high side back 100 Hz, you should be able to transmit.
  • Dom wa2got
    Dom wa2got Member ✭✭
    Hello Len. Thank you. That was it. I had 3100 backed it off to 3000. I was fiddling with FLdigi few weeks ago and the instructions had me change the high cut. Forgot about that change I made.
  • Ken Wells
    Ken Wells Community Manager admin
    That is why I use different Mic Profiles for Digital, SSB, FM, and AM.
    Then I can enter appropriate settings for each mode and not need to remember them.
