3K from band end - transmission interlock
Dom wa2got
in SmartSDR+
At 14.347.0 transmission interlock appears. If I go to 14.346.9, no transmission interlock. Same occurs on 15m band end. Haven't tried other bands. I use to be able to transmit 3K from the band end. Do I have some setting that is incorrectly set?
Hi Dom, if you cut your TX Filter high side back 100 Hz, you should be able to transmit.
Hello Len. Thank you. That was it. I had 3100 backed it off to 3000. I was fiddling with FLdigi few weeks ago and the instructions had me change the high cut. Forgot about that change I made.
That is why I use different Mic Profiles for Digital, SSB, FM, and AM.
Then I can enter appropriate settings for each mode and not need to remember them.
2
- 693 The Flea Market
