CTCSS and Transverter
Since I would also like to use Flexradio via transverter for 2m and 70cm, I find it annoying that
CTCSS is only available on the TX side.
Even more annoying is the lack of CTCSS on the RX side.We have several repeaters here that operate in multimode.The lack of RX CTCSS also allows other modulations to pass through.
It does not prevent the CTCSS frequency from being stored in the channel memory.
100% Flex needs to add RX CTCSS and TX/RX DCS. We also need a user adjustable high pass filter in the AUDIO path that can be used to filter out lower audio frequencies so we don't have to listen to the CTCSS hum on receive.
Yes, please!! For some unknown reason, they allowed a repeater to occupy a frequency out of the local band plan, right next to our club repeater frequency. With tone squelch, I would be able to monitor the club repeater without the other repeater blasting through.
- 681 The Flea Market
- 393 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
