VFO B "FB;" & "FT;" do not work when split is initiated via SmartSDR GUI
n3oc
Member ✭
Hi I am new to Flex, so maybe I don't understand this correctly. But I did search and looks like this issue has come up before, so I think it is valid.
I understand there is no true VFO B. I get it.
CAT does not report VFO B frequency or split unless split is initiated from CAT with FT1;
If you initiate the exact same spit scenario from the GUI, by pressing the split button, FB; does not work. It will only work if you initiate split from CAT.
This is a problem for those of us with solid-state amps that absolutely must know the transmit freq for every PTT or risk blowing the amp because the tuner is not informed of the correct tx freq.
N1MM does not see split either, unless it initiated the split. Then VFO B can be read and split is fine, and can be toggled on and off.
But if you do it strictly from the SmartSDR GUI, all the devices dependent on CAT are blind to this tx freq change.
I hope I am just doing something wrong, but I don't think so.
Rig is 6400 and firmware and SmartSDR are 4.1.5
Has this always been this way, or is this something new/bug in 4.1.5? Or am I missing something to initiate proper split just from the GUI, I am just pressing SPLIT and the GUI looks exactly the same as if CAT sent FT1;
thanks!
Brian N3OC
thanks!
Brian N3OC
some further info....
this is a bug, how do I inform them for a future release?
I see now that FA; just changes to the split freq when you click split.
However, it ONLY works on the USB Cables CAT connection, that CAT switches FA; to the split tx freq
the regular CAT connection via serial cable, either existing or FlexVSP do not report the split tx freq with FA; they just continue to report the rx frequency
is this by design, or is this a bug? I would think both CAT connection types would report the same info, so I think this is a bug
Brian N3OC0 -
Brian, submit a helpdesk ticket and just include everything already stated above.
Screenshots and/or videos also help too.
https://helpdesk.flexradio.com/hc/en-us
Top right - Submit a request
This is a separate website from the community so you will need to create a new login etc.
thanks Rich, I did, with screen shots and smartsdr debug screenshots
the two different CATs definitely report different information, which does not seem right0
- 379 Community Topics
- 631 The Flea Market
- 123 SmartSDR+
- 193 DAX
- 39 Aurora
- 948 Maestro
- 925 Genius Products
- 337 Tuner Genius XL
