Re-activating a long unused 6300
Hello, community. My 6300 has sat unused for about 5 years now. I want to get it going again. My current laptop which I would use to control it has never had SmartSDR on it. I assume I may need to update firmware? If so is there cost involved? Can I use the old firmware with new version of SmartSDR? Please advise on what steps I need to take to get going again. Thank you!
Hi David, the firmware version must match the SmartSDR version on your computer. I would suggest loading V 4.1.5 from the Flex website. Start it, and when prompted, select Upgrade. If you are unable to upgrade, submit a Help Desk ticket. Some older versions have had issues upgrading, but Flex Support can work you through that.
Once you are upgraded, you will have the opportunity to upgrade to SmartSDR+ or to Get Early Access (pick one or the other, but not both). You don't have to upgrade to SmartSDR+ if you are happy with the features that you are currently licensed for. Take a look at the Flex website for more info on how this works and what you get for the money.
Thank you very much for your help, Len.
You are very welcome! Were you able to get the radio upgraded successfully?
- 390 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 58 Aurora
- 974 Maestro
- 947 Genius Products
- 127 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
