How do I key the 8600M directly with a paddle while running it remotely over an LAN?
I cannot get the transmitter to key with my paddle directly connected to the key jack while running remote using SmartSDR 4.1.3. The radio is 50 ft from the operating position. I ran a two-wire shielded cable from the radio to my paddle. If I get the transmitter to key I would also like to get a sidetone on my PC speakers.
    You can extend the Key jack like you said and also extend the speakers for the sidetone.
    -or-
    The easiest way is to invest in a Morconi and do it all over the network.
  • jpotter0
    jpotter0 Member ✭✭
    Something is blocking keying by direct connection when operating the Flex 8600 remotely over my LAN. It may be a bug or a feature.
    There should be no restriction at all. I do it all the time.
    Can you post some screen shots?
  • David Decoons, wo2x
    I second the MorConi. Tou can have two different profiles set up in the MorConi, one for local LAN and one for remote.
  • jpotter0
    jpotter0 Member ✭✭
    Mike-VA3MW, Thanks for the reply. I'll get some screen shows when I get back to it. Right now I am trying to get WSJT-X running and having DAX issues.
  • jpotter0
    jpotter0 Member ✭✭
    I have an order in for a Winkeyer USB. It is supposed to arrive Monday. Either this will then be a moot point, or there will be a whole new can of worms.
  • Dan Trainor
    Dan Trainor Member ✭✭✭
    I use a Maestro B in SmartControl mode as my keyer for remote operation. If I do not feel like lugging Maestro around, I use a Hallikey usb plugged into my MacBook.
  • jpotter0
    jpotter0 Member ✭✭
    Does the Hallikey work with Windows 11?
  • WX7Y
    WX7Y Member ✭✭✭✭
    3rd YES for the Morconi
  • Dan Trainor
    "Does the Hallikey work with Windows 11?" No only Mac.
  • John WA7UAR
    John WA7UAR Member ✭✭✭
    Hallikey “works” with Windows (for a PTT switch or foot pedal) but it does not work for CW. The Mac program has a built-in Winkeyer which can be activated using Hallikey… but the PC program has no built-in Winkeyer.
