How do I key the 8600M directly with a paddle while running it remotely over an LAN?
You can extend the Key jack like you said and also extend the speakers for the sidetone.
-or-
The easiest way is to invest in a Morconi and do it all over the network.
Something is blocking keying by direct connection when operating the Flex 8600 remotely over my LAN. It may be a bug or a feature.0
There should be no restriction at all. I do it all the time.
Can you post some screen shots?
I second the MorConi. Tou can have two different profiles set up in the MorConi, one for local LAN and one for remote.
Mike-VA3MW, Thanks for the reply. I'll get some screen shows when I get back to it. Right now I am trying to get WSJT-X running and having DAX issues.0
I have an order in for a Winkeyer USB. It is supposed to arrive Monday. Either this will then be a moot point, or there will be a whole new can of worms.0
I use a Maestro B in SmartControl mode as my keyer for remote operation. If I do not feel like lugging Maestro around, I use a Hallikey usb plugged into my MacBook.
Does the Hallikey work with Windows 11?0
3rd YES for the Morconi
"Does the Hallikey work with Windows 11?" No only Mac.
Hallikey “works” with Windows (for a PTT switch or foot pedal) but it does not work for CW. The Mac program has a built-in Winkeyer which can be activated using Hallikey… but the PC program has no built-in Winkeyer.
My situation is this: I am running my Flex 8600M remotely on my LAN with SmartSDR 4.1.5. I want to set up CW operation while avoiding issues with Windows 11. I have wired my paddle directly to the radio's back panel. I observe the following:
CWX keys the rf.
I can also key the RF in the TUNE mode.The rear key jack connected directly to the paddle does not key the rf. (It did at one time, but not now.)
The Acc Pin 4-to-ground (pin 5) does not key the transmitter.
This seems to be a setup problem, not a hardware problem, but I have not been able to make it work.I also wired amplified speakers to the headphone output in hopes of getting a sidetone, but so far no sidetone even in TUNE mode when the paddle keys the rf. I do get the sidetone on my computer speakers with WRX.
Some screenshots are attached.
- 383 Community Topics
- 639 The Flea Market
- 146 SmartSDR+
- 434 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 200 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
