I'd like to use my BAL XLR microphone as the default input on the BAL
capiwal
Member ✭
Hello, I'd like to use my BAL XLR microphone as the default input on the BAL connector. Unfortunately, I can't get it to work. Is there a trick to it, or is it simply not possible to use it as the default on the BAL connector? I can change it in the MIC menu, but when I press the PTT button, it always reverts back to MIC. What could be causing this, or what am I doing wrong? Thanks, Carsten
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsHi Carsten
What version of SmartSDR? I would try 4.1.5 and if it still doesn't work, reset the radio and after that if you still have an issue, I would open a support ticket.
GL
- 197 SmartSDR+
- 322 Shack Infrastructure
- 227 Networking
