cw read built in .
Hi i would love to see a dedicated cw read function even the 7300 mk2 has it .
its a great tool for improving rusty cw skills we have a CWX keyer etc .
6 votes
Active · Last Updated
  • N5NHJ
    N5NHJ Member ✭✭✭
    There are so many CW reader applications already available.
    Download the one you like more and interface it with the DAX.
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    The Flex system design philosophy puts the radio at the center supplying all the data from the radio to external applications. This allows each ham to configure their custom installation. This is similar to configuring a stereo system from chosen components rather than a combined console stereo of manufacture chosen items.
    I think you'll find that SDC Skimmer will exceed any expectations you have for a CW reader.
  • Dan Trainor
    Dan Trainor Member ✭✭✭
    edited December 21
    SmartSDR for Mac has built-in CW decoder. It works really well.
    edited December 22
    The MAC has some great features. I tried the CW Decoder and it worked on a single signal but not on the entire band. If there was N1MM for MAC I might use it more. There are many loggers for MAC but a lot of the tools we use in N1MM for hunting down multipliers and SO2R operation aren't there. As we know, there isn't a perfect solution for all users.
    I am disappointed that the MAC software has a complete robot mode for FT8. You can set it and forget it. No one talks about it since it is the elephant in the room.
    I just tried to implement his S.A.T control but I could not get it working correctly and he hasn't written it up fully yet.
  • Dan Trainor
    Here are the built-in Tools within SmartSDR for Mac application:
    • CW Keyer
    • Keyboard Shortcuts
    • Controllers (MIDI, CTR2, CTR Dial, FlexControl, RC-28)
    • Command Bar
    • Ultra Beam
    • Metropwr
    • Waveshare
    • S.A.T. Controller
    • FlexControl
    • RC-28 Controller
    • Network Stats
    • Genius Devices
    • Band Plan
    • Frequency List
    • Call Lookup
    • DX-Cluster, and POTA (Spots)
    • PSK Reporter
    • Voice Macros (Voice Keyer)
    • Alerts
    • Logbook
    And here are the Modes supported internally:
    • CW Decoder
    • HF Fax
    • SSTV
    • RTTY
    • PSK
    • APRS
    • FT8  (FT8 tool also handles FT4 inside it)
