New 60-Meter Privileges
Jim  KJ3P
Jim KJ3P Member ✭✭✭
An FCC Report & Order was issued this week, containing some additional QRP space on 60 meters. These frequencies probably cannot be used until the R&O is published in the Federal Register. Here's hoping that the ARRL will issue some sort of guidance.
Question: Does SmartSDR+ automagically get a new Turf file when appropriate?
  • Jim  KJ3P
    Jim KJ3P Member ✭✭✭
    Here's the Report & Order…..
    FCC-25-60A1.pdf
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Hi Jim… TURF files are radio-specific, if I recall correctly. So the short answer to your question is probably No, it doesn't happen automagically. When Canada opened up a portion of the 60m band, I had to ask the Help Desk and they generated one for me.
    I suspect, tho, that Flex has some way of autogenerating a new US TURF file for all the radios out there (or sending one via the SmartSDR server) registered in the US, once the new rule is formally adopted. Either that or there's going to be a WHOLE bunch of emails with new TURF files flying around. :-)
    We are aware of this.
