Slice-Master v.0.11.0g program don't work with new firmware 3.10.10
13»
  • Erik Carling EI4KF
    Hello Alex, yes I did read. I have Slicemaster and it does not work now. But as I said I do not understand the need for it. I use JTDX connected directly and it is perfect. I have CWSkimmer and I re-installed it with SDR Bridge and it works like it always did. That is why I mentioned it. But SDC is far superior as a skimmer and is seamless with Flex radios.
    Now you ask about CW Skimmer without SDR Bridge or Slicemaster. But it must have something to create a bridge because it was designed for legacy radios and not SDR. On its own it cannot work, it must have Slicemaster or SDR Bridge or there is another even more complicated method.
  • Alex - IK5PWJ
    Alex - IK5PWJ Member ✭✭
    Hi Erik, yes I understand and I installed SDC too and it works, but I honestly like and use the CwSkimmer program faster, so I'd like to continue using it...
    Anyway, a question since I haven't tried Flexradio with version 4.0.1 with SDR-Bridge and CwSkimmer: can you confirm that you use Flexradio version 4.0.1, with SDR-Bridge version 3??? and CwSkimmer 2.1?
    If so and it works as you say, which version of SDR-Bridge do you use?
    73 Alex ik5pwj
  • Dave_N8IQV
    Dave_N8IQV Member
    I ran into the same issue when I upgraded my 6500 to 4.0.1.39161 this evening .. My Slice Master v0.11.0g stopped opening all the various apps .. I noticed an anomaly that Slice Master WOULD work and open the apps when I choose a profile that used all 4 pan adapters on my 6500 .. After reading this forum then going into my DAX menu I noticed ALL my IQstreams and RXstreams were turned ON even though I only choose a one pan adapter screen ... I tried turning OFF all the IQstreams and RXstreams except the one being used and I was able to get Slice Master to work correctly ... So for me, turning off the unused streams before starting Slice Master allowed Slice Master to open all the programs as it should ... Just a work around for anyone this may help ...
  • borreg
    borreg Member
    Dave_N8IQV, Thank you for the tip. Now my Slicemaster 600 (v0.11.0g) works with Flex 6400 and Smart SDR 4.0.1, turnig off unused IQ and Dax....
  • AC8NW
    AC8NW Member
    I would like to relay my experience with Slicemaster 6000 and SSDR versions higher than 3.1.19. I was using v3.8.2 when v4.0.1 came out. Installed that and Slicemaster stopped launching WSJTX when I would open it. Same errors that Alex posted. Tried not auto launching DAX when opening SSDR, then opening SM, then launch DAX. that would not work. Anyway, went back to v3.8.2, SM works. Decideed to experiment, and installed v3.9.18, SM works fine. Went to 3.9.19, SM still fine. went to v3.10.10, SM not working. Same with v3.10.15 and v4.0.1. Could never get SM to launch WSJTX with anything higher than v3.9.19. Ten v4.1.3 came out, and I installed it. Forgot I had unchecked the auto launch DAX button, and opened SSDR and then SM. All I saw was a message at the bottom of SM that no audio channels were present. Remembered that DAX was not open, and launched DAX. Then 2 instances of WSJTX opened! Then closed everything, and re opened SSDR and opened DAX, then opened SM. Back to not launching WSJTX with the same errors as Alex posted. Turned off auto launch DAX again, and closed everything, re opened SSDR and SM, when SM displayed the mixer panel, I launched DAX, and WSJT opened again. This is very repeatable, and works every time. So at least I can use V4 now with SM, just have to leave the auto launch DAX unchecked. This is a strange issue, and seems to be reported most by 6500 owners. Something seems to have changed with v4.1.3 that at least allows SM to find active slices, and I am fine with the manually launching DAX to enable SM to work. Just thought I'd share for the benefit of other frustrated 3.10 to v4.0 users.
    73, Scott AC8NW
    Strange
    I just brought up 4.1.3 connected to the AU-520 and it autostarted both WSJT and JTDX. The radio was already in DIGU.
    I wonder if there is some corruption in your Slicemaster INI file?
  • AC8NW
    AC8NW Member
    Thanks.Mike. I had seen references to the .ini file, but didn't pursue it because sm worked fine with earlier versions. I'll try deleting the .ini file and let SM create a new one at next launch. At least that's what other posts have said would happen.
  • Alex - IK5PWJ
    Thanks to Dave N8IQV and AC8NW for the posts, I tried to do as you indicated and Slicemaster works. You have to close both the DAX RX and IQ and after slicemaster has connected to the radio, activating them again everything works.... So it all depends on the lack of connection between Slicemaster and the Flexradio.
    You need to close all the DAX and reopen them but this should work fine. Hopefully Donald K1DBO can solve the problem in the future.
    Regarding the .ini file created by slicemaster, I tried deleting it at the beginning and then recreating it when slicemaster starts, but unfortunately it doesn't work for me.
    I repeat, I use Windows 11Pro version 24H2 with flexradio 6600 and slice-master v0.11.0g
    Thanks for the info....73 Alex ik5pwj
  • iz7auh
    iz7auh Member ✭✭✭
    Great thanks to Dave's suggestion, it works for me now too, now I wonder why SM isn't being fixed? Is there no interest anymore?
