UPDATE TO V4.1.3 HAS NOW BUSTED THE ANF
Ken Thompson
Ken Thompson Member ✭✭
edited December 4 in FLEX-6000 Signature Series
Is it just me?
Since updating to V4.1.3 Basic my ANF is not working.
and the NB is still not fixed.
So for me things are going from bad to worse.!!
Ken VK6AKT
Flex 6400 Windows 11
    Ken
    Move back down to 4.0.1 and see if you have the same result.
    You might also want to try a radio reset to see if that clears the problem.
  • Dan_K0TI
    Dan_K0TI Member ✭✭
    I agree ANF doesn't work on 4.1.3 on 6600. It does seem to take out the tones from a modulated AM signal but not the carrier. IE tune to WWV in USB mode and tune 1k low. It won't take out the carrier. The new SmartSDR+ options ANFL and ANFT do work if you have subscribed to that. Seem like in making the new options they broke the old options.
  • Ken Thompson
    Radio Reset did not fix anything.
    But moving back to V4.0.1 did bring back the ANF.
    NB is still not working.
    So on my 6400 updates to v4.1.3
    NB not fixed ANF not working as it should and it swapped my license from V3 back to V2
    Cheers Ken
  • Karl KB2AS
    Karl KB2AS Member ✭✭
    I thought I was the only one having this issue.
    Radio is a 6700.
    After updating to V4 basic, ANF no longer works. Reset to defaults made no difference.
    Currently on 4.1.5. Went back to V4.0.1, made no difference.
    I am not sure it is wise to go back to V3 so that has not been attempted.
    WNB and NB are also ineffective.
    All DSP functions worked in V3.
    Karl -KB2AS
